thank you for explainingbmcculla said:Pot is short for potentiometer which is a variable resistor. The 5K is the maximum resistance. Pots have 3 legs and will have a knob or screw that lets you change the resistance.
An analog meter could be a couple things but most likely its an electromechanical indicator - a needle with an electromagnet that moves the needle based on voltage
You might want to start with something a little easier than a lie detector. Try building a couple op-amp amplifier circuits first - these will be easier to test and less frustrating.
bmcculla said:Try building a couple op-amp amplifier circuits first - these will be easier to test and less frustrating.
