weak pull ups or not?
SnM
Right now I have a project that uses some swiches for controlling the microcontroller. (pic 12C508A) I supply the switch with +5 volts and a 10K resistor, and connect the other pin to the input of the microcontroller. To keep the input from floating while the switch is open, I put a 1M pull down resistor to ground. When the switch is open, the input is low, when the switch is closed the input is high. Works great.
Now, would it be better to use the weak pull-ups feature for the inputs? that way I could remove the pull-down resistors and instead of supplying the other end of the switch with +5 volts, I could tie it to ground.
What is the resistance of the weak pull up?
Do you see any problem with my logic? If I can connect my switches this way, I can save myself 1 wire (+5v).
Thanks!
Nigel Goodwin
Super Moderator
Most Helpful Member
That's what the weak pullups are for, you simply enable them and have your switches down to ground. The actual values of the pullups are given in the datasheet, but I seem to remember they are in the 200-300 KOhm range.
