setting weak pull ups on portb
MrDEB
using an 18f43k22 and need to set the portb weak pullups as I am using tactile switches on all 8 pins of port b.
found this but not sure if it is correct?
intcon2bits.rbpu=0
SOMETHING WRONG?
the setalldigital should disable ADC
I have the switch connected to grd
the other side of the switch is connected to portb.0
pressing the button has no effect?
portb pullups configured correctly?
*  Name    : UNTITLED.BAS                                                   *
*  Author  : [select VIEW...EDITOR OPTIONS]                                 *
*  Notice  : Copyright (c) 2021 [select VIEW...EDITOR OPTIONS]              *
*          : All Rights Reserved                                            *
*  Date    : 7/18/2021                                                      *
*  Version : 1.0                                                            *
*  Notes   :        *
// tone generator using CCP compare
Device = 18F43K22
Clock = 64
Include "intosc.bas"
#option DIGITALIO_INIT = true
Include "setdigitalio.bas"
// specify tone library output pin
#option _TONE_OUTPUT_PIN = PORTD.2
Include "tone.bas"
Dim ix As Byte
Dim note As Word
DIM SWT1 AS PORTB.0
DIM SWT2 AS PORTB.1
DIM SWT3 AS PORTB.2
DIM SWT4 AS PORTB.3
DIM SWT5 AS PORTB.4
DIM SWT6 AS PORTB.5
DIM SWT7 AS PORTB.6
DIM SWT8 AS PORTB.7
INPUT(SWT1)
WPUB=255
main:
    // init tone library module
    tone.init()
     IF  SWT1=0
    THEN
    TONE.PLAY(NOTE_F4)
    DELAYMS(1000)
     tone.stop()
    ENDIF
    // play A (440) until stop()
    tone.play(NOTE_B4)
    DelayMS(1000)
    tone.stop()
    // play all 88 notes for 100msecs each
    For ix = 0 To Bound(tone.notes)
        note = tone.notes(ix)       // current note
        tone.play(note, 100)
        While(tone.isPlaying())
        End While
        DelayMS(10)                 // short delay between notes
    Next
    While (true)
    'IF  SWT1=0
    'THEN
    'TONE.PLAY(NOTE_F4)
    'DELAYMS(1000)
     'tone.stop()
    'ENDIF
    End While
intcon2bits.rbpu=0
Not sure where you found that, but that syntax won't work w/SF unless you have something to define it that way.
It does.
WPUB sets a pullup enable mask, but it doesn't turn them on.
To do that, you have to set INTCON2.bits(7) = 0 (bit 7 is the RBPU bit).
See datasheet section 10.3
Try:
*  Version : 1.0                                                            *
*  Notes   :        *
Device = 18F43K22
Clock = 64
Include "tone.bas"
Dim ix As Byte
Dim note As Word
DIM SWT1 AS PORTB.0
DIM SWT2 AS PORTB.1
DIM SWT3 AS PORTB.2
DIM SWT4 AS PORTB.3
DIM SWT5 AS PORTB.4
DIM SWT6 AS PORTB.5
DIM SWT7 AS PORTB.6
DIM SWT8 AS PORTB.7
' make all of PORTB inputs
TRISB = $FF
' set pullup enable mask for all PORTB pins
WPUB = 255
' and turn on the pullups (RBPU=0)
INTCON2.bits(7) = 0
main:
    tone.init()
    tone.play(NOTE_B4)
    DelayMS(1000)
    tone.stop()
        End While
    Next
    While (true)
        IF SWT1=0 THEN
            TONE.PLAY(NOTE_F4)
            DELAYMS(1000)
            tone.stop()
        ENDIF
    End While
will give it a go.
assembled this morning an 8 tactile keypad so I can get the correct melodies for different tunes.
Apologies... I saw Intcon2 and assumed... !WPUB was always in the option reg... Once again sorry MrDeb..
You will still need the WPUB to set them all on..
However PBADEN is in the Config setup... I don't know whether AllDigital switches it off or not!
I saw Intcon2 and assumed. ..
It is an odd place to put the WPUB control, but that's Microchip for ya.
It doesn't.
The SetAllDigital() routine sets the port analog control bits for all the pins to digital mode (ANSELx=0 for the K22).
It does a few other things as well, such as turn off the comparators and set pin slew rate to normal.
When I said it disables the ADC that wasn't really true...
Well now to fine tune the melody to twinkle twinkle little star and adjust for proper notes. It sounds like the twinkle melody but needs work.
Need to add code for LCD and sub routines for HAPPY BIRTHDAY, JINGLE BELLS, MARY HAD A LITTLE LAMB AND LONDON BRIDGES. Almost forgot BABY SHARK. Then add in LEDs.
[CODE Swordfish basic]
Device = 18F43K22
Clock = 64
Include "tone.bas"
Dim ix As Byte
Dim note As Word
Dim SWT1 As PORTB.0
Dim SWT2 As PORTB.1
Dim SWT3 As PORTB.2
Dim SWT4 As PORTB.3
Dim SWT5 As PORTB.4
Dim SWT6 As PORTB.5
Dim SWT7 As PORTB.6
Dim SWT8 As PORTB.7
'input(swt1)
TRISB = $FF
WPUB = 255
INTCON2.bits(7) = 0
main:
tone.init()
//INTRO PLAY ALL 88 NOYES
End While
Next
While (true)
'If SWT1=0 Then
tone.play(NOTE_C4)
DelayMS(1000)
tone.stop()
' EndIf
' If SWT2=0 Then
tone.play(NOTE_c4)
DelayMS(1000)
tone.stop()
' EndIf
' If SWT3=0 Then
tone.play(NOTE_g4)
DelayMS(1000)
tone.stop()
' EndIf
'If SWT1=0 Then
tone.play(NOTE_g4)
DelayMS(1000)
tone.stop()
'EndIf
'If SWT2=0 Then
tone.play(NOTE_a4)
DelayMS(1000)
tone.stop()
'EndIf
' If SWT3=0 Then
tone.play(NOTE_a4)
DelayMS(1000)
tone.stop()
'EndIf
'If SWT1=0 Then
tone.play(NOTE_g4)
DelayMS(1000)
tone.stop()
'EndIf
'If SWT2=0 Then
tone.play(NOTE_f4)
DelayMS(1000)
tone.stop()
' EndIf
' If SWT3=0 Then
tone.play(NOTE_f4)
DelayMS(1000)
tone.stop()
'EndIf
' If SWT1=0 Then
tone.play(NOTE_d4)
DelayMS(1000)
tone.stop()
'EndIf
'If SWT2=0 Then
tone.play(NOTE_d4)
DelayMS(1000)
tone.stop()
'EndIf
' If SWT3=0 Then
tone.play(NOTE_c4)
DelayMS(1000)
tone.stop()
'EndIf
End While[/CODE]
