Voltage Stepping Circuit
fantasymick
I'm trying to build a circuit that can produce voltage steps in response to a standard rising or falling trigger signal. For example, on the first trigger signal, the output will be -1.5V and hold there. On the next trigger signal, it'll be 0V and hold. Then 1.5V, 3V, and repeats. -1.5, 0, 1.5, 3, -1.5, 0, 1.5, 3 V etc..
I tried doing it in software using labview but it wasn't responding beyond triggers above 3 kHz. For my application (optics and phase modulation) I need ~ 25 kHz.
Can someone point me in the right direction on how to build such a circuit?
Thank you.
Thank you.
You could do it usng a HEF4017, with outputs into a 'weighted' OPA summer, requires a +/-5V for the OPA power supply.
Do you follow.?
Do you follow.?
Right. Alternative to the weighted summer would be to drive an analog multiplexor that will switch your input levels (voltage divider / buffered)
Your scanning / switching rate would be determined by the analog mux (25kHz -feasible)
again, +/- supplies needed.
Switching rate with the OPA solution probably determined by slew rate & load of the opamp.
