I need to provide exact voltage 0-1v to control current through a driver IB462H with the picture of the page below. I am hesitant using resistors to control the voltage since the output voltage may change if there is a variation in the current.
all the voltage regulators I found start around 1v and up. is there a regulator or another solution to that would output <1v? Easily adjustable regulator will help since I may change the voltage time to time (for 1.2amp vs. 2amp motors) but more "permanent" solution will be fine too.
P.S. I am also little confused about the resistor value table: how the higher resistor values would give higher current since the formula shows that the current increases with the increase in voltage (closer to 1v should output 1amps). Am I missing something?
P.S. the voltage divider current referenced in the text uses IC 71HC123 to cut down current when not stepping and should not matter for this question - I assume.
