Voltage reference with a zener diode
Futterama
Hello forum,
Can you please advise me on either, how to make a voltage reference using a zener diode (Philips BZV55 voltage reference diode), or how to use the Zetex ZR431 zener shunt regulator as a voltage reference.
I need a voltage reference to measure when the supply voltage (battery supply) reaches a certain voltage. I'm using a PIC with ADC and need a voltage reference for it. My battery supply can vary from 4V to around 10V (different number of cells being used).
I have access to both the BZV55 and the ZR431 and I have played around with both of them, and I just can't get a stable reference voltage.
I would like the reference voltage to be 2.5V with the ZR431 and any value below 4V for the zener (I have different zener voltages to choose from).
A circuit diagram would be much appreciated.
Thanks.
Regards,
Futterama
Futterama said:
Hello forum,
Check my analogue PIC tutorials, which use the 431 - this is a precision reference, a simple zener will be pretty poor as a reference.
Hello Nigel,
Could you please post a direct link to the page where I can find circuit diagrams using the 431? I'm having trouble finding it on your website, sorry :roll:
Futterama said:
Hello Nigel,
OK
Nigel, it works just fine!
The reference is 2.58 at my multimeter, regardless of input voltage variations. It should be a 0.5% reference (I use the SOT23 package), perhaps my multimeter is incorrect.
Thanks Nigel!
Edit: My multimeter must be out of adjustment! I just borrowed a FLUKE 87 that should be correct, it showed 2.497V.
Thanks Nigel!
That's always the problem, you don't really have an accurate way of adjusting a voltage - unless you send your meter for expensive annual calibration, which isn't really worth it for domestic use (or most professional use either!).
It's not a bad idea at this point to check out the Maxim and Analog Devices sites for IC voltage references. They make very accurate references available in a selection of voltages and will usually provide free samples.
Dean
Or you can get them out of many scrap TV's and VCR's. The 431 is often used as a PSU feedback reference.
