Voltage gain of DTMF decoder
The attached DTMF decoder configuration was taken from the datasheet of the MT8870 DTMF decoder but i'm seeing that in order to calculate the gain, the gain formula have a S...What is this S?... Do i just use the gain as Rf on R? The equation is on page 9 of the attached document.
Regards.
  • MT8870 DTMF Applications.pdf
Ignore the S stuff, Just use the Rf/Ri formula. Close enough.
Voltage Gain
Thus the voltage gain of the attached circuit would be 150K/(56K + 56K) right? and not 150K/56K
  • Testing MT8870 DTMF Decoder.pdf
Voltage Gain
Lol...Oh well i'm seeing the voltage gain on page 5 for the differential configuration on the MItel datasheet is R5 on R which is the same as Rf on R in the testing circuit i attached earlier so that should be good...Thus it should be 150K/(56K+56K) which is approximately 1 so i don't see the sense using the differential configuration with a gain of almost 1 when there is a single ended input configuration with unity gain available. Unless the DTMF decoder is that sensitive to changes :confused:
Differential has the benefit of noise reduction. The + noise on terminal a cancels - noise on terminal b. Does that make sense?
Diff. Configuration
Ohhhh yea makes sense...think i read that later down in the Application note...thanks for the refresh of memory...:)
hi dramrattan,
Consider what effect the Source impedance has upon the gain, its a nominal 600R.
Also a single ended input will give no common mode rejection, whereas a differential input will.
Diff. Input Config
Yea it was mentioned that the zero formed on the '+' when Ra is choosen os canceled by the pole formed by calculating Rb:
Rb = Ra X Rf/(Ra+Rf)
I can't remember what is a POLE and what is a ZERO so i trying to figure that out for the while
hi dramrattan,
That is what I was trying to say... :eek:
Thanks eric gibbs...makes sense
hi dramrattan,
This is your cct with a gain of 2, [6dB], I have used a single ended input for demo.
The 3dB point is about 70Hz.
What did you use to simulate the circuit?...How do yo know the gain is 2 from that graph? :eek:
LTSpice.
The gain 6dB, look at the left Y axis of the graph at the 0bB line, the flat portion of the gain curve is on the +6dB line... OK.?
He might be asking, how do you decide on what the gain should be set to.
