swordfish12
(the voltage indicated at the emitter should be 19.3 volts. )
hi everyone, i have a doubt(proabably a silly one), yet i am unable to figure it out,
in the attached image, suppose there is no controller. And instead of a 11.5V battery at the collector of pnp transistor, we have a 0.25 ampere constant current source connected.
now assuming base current to be negligible, the emitter current is almost 0.25ampere. therefore the voltage drop across the current sense resistor(1.4 ohm) is 0.25*1.4=.35V .... now the voltage at emitter is 20-0.35=19.65 volts.
since we assumed active mode, the voltage difference between base and emitter is 0.7 volts. but we are getting 19.65-18.6= 1.05volts. but the voltage drop across a silicon diode can only be 0.7 volts.
what am i missing here. please correct if my analysis is wrong.
