OK, I have been in here before asking about this and got a bunch of good info to at least better understand some things.
What I have before me is a 9" CRT that is on its way out or at least needs fixed. The screen is overly bright with some horizontal lines. However, I do NOT want to even mess with it. It needs an updated display. The current CRT is monochrome.
I recall that someone taught me about TTL and how that is vastly different than 'VGA'? Or other technology. There was also a sync frequency I believe that was probably different.
Now, on this machine, there was a color LCD option so there is a possibility the video output and connector are the exact same and the display unit is different, meaning there is hidden potential. However, the OEM made their own "Honda" connector for these, so all the wires would have to be determined and converted to a proper DB connector.
I would like to discover how to use the scope to determine what I have? If it is TTL, should I not see some square wave action? Then ID'ing the rest of the wires.
I did find and purchased an "XVGA" converter box that was specifically designed to convert stuff like this. In either case, I still have to convert to a DB connector for it but I feel these converter boxes are wildly overpriced for what they are. I plan to go open the one I have to see what is going on there. Would sure like to find someone very sharp on this stuff. I am pretty clueless when it comes to video.
