Hey guys. I’m working on a 2001 Honda rubicon 500 atv. A common problem with these is the display goes out. You can get it to work temporarily by doing the following. Turn the key switch to the on position then pull the fuse, then reinstall the fuse. The display will work properly until you cycle the key. Once the key has been turned off it will not turn back on. Unless you repeat the fuse pulling Here is a link that is on YouTube showing this process.
I am very green on electronic repairs. Any thoughts on what would cause this issue? It seems odd to me that by having the key on then pulling the fuse would get it to work. Any help would be appreciated
