shanku_16in
Hello.
i am a project trainee in TCS. I have been given the task of finding a video capture card with the following specifications:
1.It should support PCI bus
2.It should work in LINUX
3.It should give a minimum capture frame rate of 30 fps
4.It should have 4 input channels
5.The output should be given in RGB
After searching a lot, all that i have managed to find have everything except the RGB output. Infact, I found an Nvidia card(Quadro SDI capture card) which even gives RGB output, but my project lead says it has too many extra features that has added to its cost substantially and is not viable for the project that i am working on.
Now the solution that i have thought to this is converting the MPEG4 output given by most cards into RGB by some additional simple hardware. But googling does not help. Can anyone please help me on this by advicing something that converts MPEG4 into RGB.
Thank you,
Siddharth
Thank you,
Siddharth
