Vacuum tube am radio
Mdkanz
I have a vacuum tube am radio that i made a 1/4'' jack output but i was reading somewhere that it can damage a tube if there is no load. so would it solve that problem to put a 10ohm resistor across + & - with a head phone jack so when the jack is plugged in the resistor is disabled?
Use a 100 ohm (or 10x the expected speaker impedance) and don't bother with a switch.
What I'd do is try a 47 ohm and see if I can even hear a difference when it is across the speaker or not.
Yes it is possible for damage to occur as the tube type radio's used a step down audio transformer. With out a reasonable load the secondary, where the normal speaker connnected the reflected impedance in the primary was very high.
A normal solution is to use a 1/4 jack that has a switch contact built in to the jack. The contacts are normally closed with out a plug in the jack, thus putting a load on the secondary. When a plug is inserted into the jack the contacts open disconnecting the load, and the load on the plug now becomes the load on the secondary.
See the attached figure.
__________________
The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best.
Show me a different way. I have an open mind.
What size resistor should i use?
I am guessing a resistor about 5 to 10 ohms @ about 2 watts. As I recall a lot of the speakers in those days were 3.2 ohms, and the amplifier was capable of about 2 watts output.
I don't get it. The reflected impeadance is high. Then what? I grew up in the age of silicon.
It's quite simple:
Transistor amplifiers are destroyed by a short circuit on the output, valve amplifiers are destroyed by an open circuit on the output.
It's a bit like a protection diode across a relay, with no load the transformer can arc internally destroying it, or it can arc over inside the valves.
Tube guitar and PA amplifiers were destroyed with a spectacular puff of smoke if the speaker circuit broke if the amp was cranked up at full power. The manufacturers followed the trend set by repairmen, who arranged for the the Speaker socket to short-circuit the amplifier if no speaker plugged in. It was better to have glowing red hot tubes with a shorted output, than to have an output transformer destroyed by internal arcing. Quite nice colours in the tube, red hot anode and blue sparkling inside, as a reminder to plug the speaker back in.
I used to repair a lot of Fender guitar amps in the 1970s.
Fender dealt with the problem by either using a neon bulb on the output transformer primary (tube side) or a one watt resistor (or two watt) (I don't remember the value but I think it was 47 ohms) across the speaker jack.
Not switched. Always in the circuit.
