USER INTERFACE:1 enter/settings switch,2switches->2digit value,LCD
Oh No...:confused:
i added the switches but when i run the code nothing appears on the screen.
Am i supposed to configure the LCD to read??? At the moment its configured for write Only. The LCD is working when i COMMENT out //menu();. It displays infra red liquid level detector. However when i UNCOMMENT menu()...the lcd does not display anything:(. I connected switches to the PIC:
RC2 //HOME switch
RC3 //INCREASE switch
RC4 //DECREASE switch
RA4 //ENTERSETTINGS switch
The code compiles with menu uncommented out but it doesnt work in the circuit.
the new functions added (which might have problems i cant spot)are:
void init(void);
void read_input_sw(void);
void ShowDigits(unsigned char ,unsigned char );
unsigned char Combine(unsigned char , unsigned char );
int enter_settings(void);
void menu(void);
Here is the code:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
void home_screen(void);
void menu(void);
void calc_distance(void);
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
char temp[8];
int height=50, SensorPos=10;
char input_sw;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4	//ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(20); //wait for LCD to be ready
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
[COLOR="Red"]void init(void)[/COLOR]
    OSCCON|=0x60; //set fosc to 4Mhz
	TRISB=0x00;
	TRISC=0xFC;
    TRISA = 0b10000010; 	// RA7 high imp, RA3 is serial out,
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
	lcd_init(); //call LCD initialisation
	OSCCON = 0x72;      	// internal osc, 8MHz
	PORTA = 0;
							// RA1 is ADC input measuring VR1
	PORTB = 0;
	WPUB = 1;
    RABPU = 0;
//	INTCON2 = 0;            // PORTB pullups ON
	TRISB = 0b00000000; 	// PORTB not used
	ADCON0 = 0b00000101;	// ADC ON, RA1 is ADC input
	ADCON1 = 0b01111101;	// AN1 is ADC input
//	ADCON2 = 0b10100010;	// right justify, 8Tad, 32Tosc
	T1CON = 0b00010001;     // TMR1 is ON, 1:2 prescale, =1MHz
//	T3CON = 0b00010001;     // TMR3 is ON, 1:2 prescale, =1MHz
	TRISC=0xFC;
	ANSEL=0x02;
	ANSELH=0x00;
	lcd_init();
	GIE=0;
	//PORTA = 0x00;*/
[COLOR="Red"]void read_input_sw(void)[/COLOR]
 char input_sw2;
 input_sw = ((HOME_SW*8)+(INCREASE_SW*4)+(DECREASE_SW*2)+(ENTERSETTINGS_SW*1)); //create a binary combination of the input switches
 if (input_sw != 0) //check if any of the switches are pressed
	 DelayMs(20); //switch debouncing
	 input_sw2 = ((HOME_SW*8)+(INCREASE_SW*4)+(DECREASE_SW*2)+(ENTERSETTINGS_SW*1));
	 while (input_sw2 != 0) //if a switch is pressed wait for release
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
//ShowDigits(3,5);
//	Displays 2 digit data to LCD
[COLOR="Red"]void ShowDigits(unsigned char var1,unsigned char var2)[/COLOR]{
	var1 += 0x30;
	var2 += 0x30;
	lcd_data(var1);
	lcd_data(var2);
//turn 2 digits from user into a single number (decimal) like
//Decimal 3 and 5 into 35(which is 0x23 in hex).
[COLOR="Red"]unsigned char Combine(unsigned char SinglePOS, unsigned char TenPOS)[/COLOR]{
   unsigned char wholeNum;
    wholeNum = SinglePOS + (TenPOS * 10);
    return wholeNum;
[COLOR="Red"]int enter_settings(void)[/COLOR]
{ int Var1=0;
  int Var2=9;
	do
    {	read_input_sw();
		switch (input_sw)
			case 8: goto a;
			case 4: { Var1++;		//increase 1st digit
					  if (Var1>9)   //increasing 1st digit from 0 to 9 only-with each press
					      Var1=0;
					  NumSep[0]=Var1++;
					  break;
			case 2: { Var2--;		//decrease 2nd digit
					  if (Var2<0)	//decreasing 2nd digit from 9 to 0 only-with each press
						  Var2=9;
					  NumSep[1]=Var2;
					  break;
			default : goto a; //should any abnormalties occur
	    	ShowDigits(NumSep[0],NumSep[1]);
	while (input_sw==1);
     NumDec = Combine(NumSep[0],NumSep[1]);
   	 return NumDec;
a:
	return;
[COLOR="Red"]void menu(void)[/COLOR]
	read_input_sw();
	while ((input_sw != 8)&(input_sw != 1))  //Wait for Home or enter/settings
		lcd_clear();
		lcd_goto_L1();
		lcd_puts(" ENTER/SETTINGS ");
		DelayS(1);
		lcd_clear();
		lcd_clear();
		lcd_goto_L1();
		lcd_puts(" ENTER HEIGHT ");
		height=enter_settings();
		lcd_clear();
		lcd_goto_L1();
		lcd_puts(" ENTER SENSOR POSITION ");
		SensorPos=enter_settings();
	// from the transeiver datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the transeiver
	// load ADC value in 16bit math var
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
void main(void)
	init();	// initialise I/O ports, LCD
	while (1)
	//menu();
	home_screen();
Configuration switches
Im not sure about this. Im new to programming the pic.
There are four items that are set when you "burn" the program into the PIC that are entirely separate from the program itself. These are set by supplying a configuration word which is burned into the PIC. The bits making up this word are formed in the line that starts...'__CONFIG'.
* Power up timer To prevent the program from starting too soon after the power is switched on, (everything may not be settled yet), you can activate a power up timer with '_PWRTE_ON'
* Type of Oscillator The oscillator you use for the PIC is either an RC oscillator, a crystal oscillator, (XT), a high speed crystal,(HS), or a low speed low power, (LP) crystal. Your circuit may not respond properly if you have the wrong oscillator type selected.
* Watchdog Timer To prevent your program from running off into 'never-never land' without the ability to recover, a watchdog timer, (WDT), can be activated. It will restart the program every 18 milliseconds or so unless a CLRWDT, (clear watchdog timer), command is executed during this period. Normally you don't want it activated,(_WDT_OFF). It can easily cause your program to seem to act strangely.
Currently in MPLAB its set as:
Power up timer: its Off
Type of Oscillator:External RC clock out
WDT:OFF
BUT
Im using the internal oscillator of the pic
so must i choose internal RC clock out??
or internal RC no clock??:confused:
Wow the read switch stuff looks way to complicated. Are you using pic lines for each button? also...
Why not use a few simply ifs?
Look at my main menu navigation:
void CheckButtons(void){
		MyButton = GetADC(0);
		if(MyButton > (MENU-2)){
			if(MyButton < (MENU+2)){
				MakeMenu(0);
				settingPos(menuPos);
				Done = 0;
				while(!Done){
					if(MyButton == UP){
							if(menuPos == 1)
								menuPos = 4;
							else
								menuPos--;
							MyButton = 0;
							DelayMS(250);
					if(MyButton == DOWN){
							if(menuPos == 4)
								menuPos = 1;
							else
								menuPos++;
							MyButton = 0;
							DelayMS(250);
					if(MyButton == ENTER){
							MyButton = 0;
							curPos = 0;
							MakeMenu(menuPos);
							menuPos = 1;
							showStart();
							Done = 0xFF;
							MyButton = 0;
Uhmmm im working with push-buttons for the first time. Yeah each switch has its own line to the PIC. Well ill try out the ifs as well-thanks
