Universal Travel Adapter PD (Power Delivery). help!
FoxAdriano
Hi, I have to admit that I am not an expert and I need some advice.I travel quite often to remote areas of Africa, Asia, South America and I need a good Universal Travel Adapter to be able to quickly recharge my devices: Osmo Pocket 3 batteries, Notebook, batteries for my lamp, etc.I need a Universal Travel Adapter PD (Power Delivery) that allows me to fully exploit my needs. Sometimes I recharge them individually but sometimes also simultaneously.I already know that these recharges can deteriorate the batteries more quickly, but I will recharge them about 4-5 times and no more on each trip. I travel twice a year, so all the other times I will recharge the batteries at home in a slower way.My question: can anyone recommend me a good and reliable plug adapter, Universal Travel Adapter PD (Power Delivery)? Could a 65W be enough?T HANK YOU for your kind replies.
My current charger by Samsyng that I bought when I got my new A16 5G Samsung, is labeled 25W. It charges it to 100%, starting with battery at 35% in about 1h 25m approx.
Start by determining what voltage levels (and therefore what power levels) are needed by each device. Probably, a laptop computer is the biggest draw – my Lenovo needs a 60 watt/20 volt PD supply. Determine the highest draw items, and which things you'll want to power/charge at the same time.
This will give you the biggest single load you have, the maximum total load, and the number of ports.
Let's say you have these devices to charge at the same time:
● Laptop, 20 volts, 60 watts
● Device x, 15 volts, 45 watts
● Phone, 9 volts, 25 watts
To charge these devices at the same time, you'd need a 130 watt PD supply with at least 3 ports.
Here's where it gets a bit tricky. Let's say you find a 5 port charger that can supply 180 watts. Looks like that's a good option. But wait. You need to determine what each port is capable of, and sometimes they aren't so forthcoming with this info. Dig into the details and you may find:
● 4 ports are capable of supplying 15 volts, 45 watts at the same time.
● 2 ports can supply 15v/45w while 2 ports can supply 9v/27w and the last port can supply 5v/10w.
● Other combinations of loads per port, totaling 180 watts.
The critical thing to note is that no port can supply 20v/60w. So this supply wouldn't work to power the laptop even if it's the only device connected. Make sure the the PD charger can supply the maximum needed voltage/power through a single port while also powering other devices.
Be very careful if any of your devices require 12 volts – 12 volt operation is no longer part of the USB C PD standard. Some supplies continue to support it but not all do.
Also, be sure that the supply can handle the needed input voltage – not all of them can handle the 100v – 240v range.
One final point: you can't power a bunch of different PD devices through a USB hub.
I don't know how to thank you for the precious information. However, what I connect to it is all under 12 volts. I ask you one last question:can you indicate some specific model of Universal Travel Adapter? I repeat: It is difficult for me to connect 3 devices at the same time but sometimes I connect 2 to the Adapter. On my trips I have to travel light.I had thought of this model, but you will surely have a better model to suggest:https://www.amazon.it/LENCENT-Adatt...7?__mk_it_IT=ÅMÅŽÕÑ&crid=OZWYNMVDDV47&dib=eyJ 2IjoiMSJ9.NOeUOKFl0LqD2XaWEk7K_HQhg8NI_7UXX2p__fj06RokBqgWWtBt87m7Z74q0pcfqaa2EQXok4lt cvQq1AOaGCK2PoSGFWkocQskC5YQhzIa8yNnIRtFT4j_nd6oB1RQM99wF6zeUmYJibw_Vneafafw4pm6CpwOIb DWJKfcpnqdkNbePS8OIhBZjDmuVRKenkb5Gjg0V6TmtqSiyUe5-Ic8DsuI9h7BuvZ1BkwQcuVGzQaVaUnEOrBl c5tNA4chqlpVpmkBnzI-0aAx7kBBg8hVd56JsM0iZnj67SQyuKs.mpCRmHbTYBFezWLjc6qrANYFZhYOytGp8l s69kNJZyw&dib_tag=se&keywords=Adapter%2BUniversal%2Bprotocol%2BPD%2B30W&qid=1745484611&sprefix=adaptor%2BUniversal%2Bprotocol%2Bpd%2B30w%2Caps%2C123&sr=8-7&th=1
When I travel for extended periods away from the grid, I rely on my trusty USB battery bank. For the Phone, I also have a mobile wireless charger disk, which is slower but cordless. Your link has only one male plug to suit your target country and the receptacle outlet supports all
I already have a Powerbank, I am looking for a Universal travel adapter for electricity. I apologize if I expressed myself badly or if I did not specify it. Sorry.
I thought all mobile chargers these days were universal AC voltage butyou may just need a plug adapter. Those are common.
Check the label fine print.
The AC plug adapter and USB are different requirements.
Which AC plug types do you need?
Which AC voltage range? dual or single?
Do you need 65 W USB total, 100W or 130W with a single Type C plug like rj. Then the plug adapter is separate item.
From Grok3 on X.com
Your travel to Africa, Asia, and South America requires compatibility with multiple plug types. Based on web sources, here are the common plug types in these regions:
  • Africa:
    • Type C (Europe-style, two round pins): Common in North Africa (e.g., Morocco, Algeria).
    • Type G (UK-style, three rectangular pins): Used in Kenya, Nigeria, Ghana.
    • Type M (large, three round pins): Standard in South Africa, Namibia, Botswana. Note: Many universal adapters exclude Type M, so ensure your adapter includes it or buy a separate Type M adapter.
    • Type D (three round pins): Used in parts of Africa (e.g., Nigeria, Senegal). Often not covered by universal adapters.
  • Asia:
    • Type C: Common in India, Thailand, Vietnam.
    • Type A (two flat pins): Used in Japan, Thailand, Philippines.
    • Type G: Found in Singapore, Malaysia, Hong Kong.
    • Type I (two slanted flat pins): Used in China, though some universal adapters rotate Type A pins for Type I compatibility.
  • South America:
    • Type C: Common in Brazil, Argentina, Chile.
    • Type I: Used in Argentina.
    • Type A/B: Found in Colombia, Venezuela, Peru.
Key Notes:
  • Universal adapters typically cover Type A, B, C, E/F, G, I, working in 150-200+ countries, but Type D, H (Israel), and M (South Africa) often require separate adapters.
  • Your adapter must support 110-240V input (standard for most USB-C PD chargers) to work globally without a voltage converter. Your devices (Osmo Pocket 3, notebook, lamp) are likely dual-voltage, but confirm this on their chargers (e.g., “Input: 100-240V”).
For the longest battery life always keep the battery between 30% to 80%.
The one I posted had three type C plus three type A sockets?
Those are USB letters
I provided the AC mechanical (male) Plug letters for each country.
Type A are two flat parallel pins used in North America, 60 Hz 120 V +/-10%
Type C are two round pins common to Europe , 50 Hz 230 V +/-10%
I'm sorry if my english is not good. It is not my mother language.
Anyway all my devices use 110-240V chargers.
I need to know what good PD Universal Travel Adapter I can buy. ONLY it. I hope you can suggest 2-3 65W precise models. Even though I might need a 100W, I would like to buy a 65W because I need it to be 2cm smaller that 100W and with less weight.
Thanks again.
EDIT: About AC plug types I need different plugs, for that reason I asked an Universal Travel Adapter.
Some types are good, some types are bad.
Unless someone has actually owned and used one, there is no way of knowing what it will be like.
eg. I also have a "72W" one, like this other than the brand stamped on the side:
It's useless - hardly anything beyond low current basic 5V stuff works correctly with it. It is about a centimetre shorter than the six output 120W one - but far heavier!
Higher power rating does not necessarily correspond to a heavier unit.
Since I haven't bought anything yet, I'd like to ask you one last question. I will only use my adapters when traveling.In your opinion, is it better to buy a 120W Universal travel adapter with USBs built in, or buy 4-5 different AC plug adapters like the one in photo 1 that cover the countries where I go and then connect an adapter like this one in photo 2? The Universal adapter with USB ports is convenient, but there is the problem that it must be inserted into a wall socket perhaps 4-5 meters away from the bed where you rest in the meantime. Instead, with the second option from AC plug adapter you can use an extension cord that reaches the bed and insert the adapter in photo 2.Which of the 2 options for you could be better for traveling?
I use option 2 - but just have different AC leads rather than adapters, as it's a separate lead with a standard plug at the back of the "brick".
eg. Need a Euro or whatever plug rather than the one it came with - just get a lead for the place you are going to. I have two pin euro and US type for my gear than has separate cables.
I agree with this. I was about to post exactly the same suggestion.
Please don't get mad at me and don't tell me to go to hell. ;) I ask you to kindly repeat what you wrote to me, but with other words because I didn't understand well. How can you plug in the power (your link) if option 2 only has USB ports? My English is quite bad. Sorry. When I understand I won't bother you anymore. Anyway, I'll do what you advise. Thanks again.
The charger in photo 2 has a mains lead that can be unplugged. The power inlet to the charger is a connector that looks like this:-
We are suggesting that you buy various mains leads, and use the correct one for each country you visit.
If you are visiting Great Britain, use one of these:-
For much of Europe, use one of these:-
For America, use one of these:-
There are others available for all countries.
You can buy a kit that is a charger plus four mains leads:-
https://gb.evolvedchargers.com/products/240w-gan-8-port-usb-c-charger
