Ultrasonic oscillator
Granny
I want to build a sinusoidal oscillator circuit around an op amp or transistor. About 100kHz at a volt or so.
My first thought was that it should include a crystal for frequency stability, but the 2 problems I had are that I can't locate a crystal of the right frequency ( there doesn't seem to be anything between about 32kHz and 1 MHz) and that even if I could I don't know how to find its inductance so I can sort out the tank circuit.
I then breadboard some RC oscillator circuits I found online, but either they don't oscillate at all or the output waveform is a long way from sinusoidal! I look at the waveform using a Pico/laptop combination.
Help with any of these problems would be appreciated.
rjenkinsgb
Most Helpful Member
Look at a "Phase shift oscillator" - they produce a pretty good sine wave.
I'd suggest trying it at eg. 10KHz first then change the timing components for the frequency you actually want.
If you use an opamp, it should be a type rated for much higher frequency than you are working with.
Also make sure the power decoupling is good, eg. something like 100uF and a 0.1uF in parallel.
danadak
Most Helpful Member
You can find 100 Khz xtals on ebay, they were quite common in communications receivers back in
the day.
There are programmable oscillators also -
And design methods - https://www.ti.com/lit/an/szza043/szza043.pdf
Regards, Dana.
Granny
Thanks! I thought I had tried that, but when I set it up just now it worked well at 10kHz. I used 1.2k resistors and 10nF capacitors with a 100k variable in the feedback loop of an op amp. Perhaps I got the feedback wrong before.
At just under 100kHz the waveform was not as good, but it will be amplified and used to generate noise using a small speaker that will be operating a bit beyond its published frequency range so the noise should be a reasonably pure tone.
AnalogKid
Most Helpful Member
A 3-stage phase shift oscillator needs a loop gain of 27. At 100 kHz that's a gain-bandwidth product of almost 3 MHz. That's a lot for a standard transistor or opamp. You would need something with extra bandwidth.
Digi-Key has 35 crystals in stock in the 50 kHz to 200 kHz range.
ak
Granny
ak
Thanks. I hadn't realised about that gain- bandwidth product. Now I have a working oscillator I would prefer to stick with it rather than move to a chrystal oscillator.
The op amp I am using is a quad TLO74CN, and according to a data sheet I have just looked at online it's unity gain bandwidth is 4MHz. I assume that means its gain-bandwidth product is the same? Is that so - it's not something I have needed to know before? If so it should be ok.
unclejed613
Most Helpful Member
yes, two ways of saying the same thing... Ft is the same thing, but for transistors., and i see some transistor data sheets also call it GBW or unity gain frequency.
LvW
Did you hear already about a GIC-based oscillator? (GIC: Generalized Impedance Converter).
It is one of the best two-opamp oscillator circuits - in particular, for high frequencies - because the non-idealities (limited bandwidth) of both opamps cancel each other (up to a certain degree).
See for example here:
Nigel Goodwin
Super Moderator
Most Helpful Member
Have you checked the PDF link I posted?, it takes you through the entire design process of the 100KHz oscillator? - you don't need to know, or calculate, anything.
Granny
I hadn't read it, but I have now.
If I can get the 28V 24mA bulb I shall give it a go.
LvW
This is the well-known WIEN oscillator. It also can be stabilized (instead of a bulb) using two diodes or any other amplitude-dependent resistive element (thermistor or FET)
Nigel Goodwin
Super Moderator
Most Helpful Member
I don't think the bulb is that critical, I seem to remember I used something different, that I got from RS Components. The point of it is to easily and cheaply stabilise the output and give low distortion.
There's a specific thermistor for Wien oscillators, the RA53 - but expensive if you can find one.
Here's another useful page:
