ULN2003 and ULN2003A
xiaobai00 said:
are they operating at same voltage or different? one with A is 12 or 5v?
As far as I know the "A" suffix just means it is in a standard DIP plastic package.
There is also a version with an "L" suffix to mean surface mounted SOIC.
Ref attachment.
ULN 2003A Darlington arrays doesn't need any voltage.
To operate a transistor the +VDD voltage path is coming through the load - through collector - & emitter through ground.There is no +VDD pin in it.
I think you mean the signal input voltage?
But the MAX current can handle to each channel will be very important.It can supports to MAX 50V load per channel.
er.. what i mean is ULN 2003A is operating at 12V or standard TTL logic level, +5V? I just want a straight answer, thanks.
The table I posted tells you what the ULN2003A accepts as inputs, its a General Purpose ALL types.
OR do you mean what can it switch??
They are just darlington transistors. They do not have an operating voltage. They can drive a load with a supply voltage up to 50V.
Look at the datasheet. The ULN2003A has a series 2.7k input resistor so it can be driven from 5V TTL or from 5V to 15V Cmos signals.
