UART interface with PIC16F886
ajit_nayak87
I am trying uart serial communication on pIC16F886 . I am using 20Mhz external oscillator frequency.For below code i am getting garbage value.
i have tested similar code on PIC18F24K40 where i am using 16Mz internal oscillator where i can able to send and receive data with same hardware . Here i am replacing MCU with PIC16F886 with external oscilator
Please let me know any problem doing while intialization
I am using asyn mode.16bit
#include <htc.h>
#include <stdio.h>
#include<pic.h>
#include<stdint.h>
#include "delay.h"
#define _XTAL_FREQ 20000000
unsigned int i=0;
  unsigned char c=0;
  unsigned char ch;
#define SBIT_TXEN 5
#define SBIT_SPEN 7
#define SBIT_CREN 4
#define LED_RX RC7 // Pin assigned RX LED
#define LED_TX RC6 // Pin assigned TX LED
#define LED RC2 // Pin assigned for LED
#define DE RC5
#define RECEIVE 0
#define TRANSMIT 1
#define READ_REG 3
#define WRITE_REG 6
#define ILLEGAL_DATAVALUE 0x03
#define FALSE 0
#define TRUE 1
#define METER_ID 1
unsigned int j=0;
unsigned char* str;
unsigned int count = 0;
char data = 0;
unsigned char rxbuf[50];
unsigned char ser_data[95];
unsigned char crc_data[95];
unsigned char Max_scroll = 0;
unsigned char buff[10];
volatile uint8_t index = 0, rec_flag = 0, Delay_count = 0, Id[10], Buffer_count = 0, Cal_count = 0, Disp_count = 0, inc = 0, One_sec_update = 0, Auto_scroll_count = 0;
char data1[10];
unsigned char buf[20];
unsigned short int cnt, num,Dgt=0;
unsigned int j;
#define Notes_Index 25
unsigned int Toff_counter=0;
unsigned int POn_Flag=1;
unsigned int Poff_Flag=0;
void Serial_1_Send_byte(uint8_t trbuf1)
 TXREG = trbuf1;
  while(TXIF==0); // Wait till the transmitter register becomes empty
void Send_string_uart1(const unsigned char *string)
    unsigned char i = 0;
    do {
        TXREG = string[i++];
        while(!TXIF); // Wait till the transmitter register becomes empty
    } while (string[i] != '\0');
char Serial_Receive_byte()
   while(!RCIF);
    return RCREG;
char usart_RxString()
   while(*str !='\0')
   { // while not end of string
      while(0==PIR1bits.RCIF);
       RCREG = *str; // read next character
       str++; // increment pointer to next character
       return RCREG; // return the contents of uart
void UART_Init(int baudRate)
    TRISC=0x80; // Configure Rx pin as input and Tx as output
   // TXSTA=(1<<SBIT_TXEN); // Asynchronous mode, 8-bit data & enable transmitter
   // RCSTA=(1<<SBIT_SPEN) | (1<<SBIT_CREN); // Enable Serial Port and 8-bit continuous receive
    TXSTA=0b00100010; // Low Speed mode
 RCSTA=0b10010000;
    SPBRG = (20000000UL/(long)(64UL*baudRate))-1; // baud rate @20Mhz Clock
void UART_TxChar(char ch)
    TXIF=0; // Clear transmitter flag
    TXREG=ch; // load the char to be transmitted into transmit reg
char UART_RxChar()
    while(RCIF==0); // Wait till the data is received
    RCIF=0; // Clear receiver flag
    return(RCREG); // Return the received data to calling function
  void Timer1_Interrupt()
  INTCON = 0b00000000;
  PIE1=0b00000001;
  PIR1=0x01;
  TMR1H=0x0B;
  TMR1L=0xDC;
  T1CON=0x31;
    TMR1IE = 1;
 TMR1IF = 0;
 // T1CON=0x01;
 void Init_Controller()
  cnt=100;
    TRISC = 0x80; //RX port configured as input
 PORTC = 0x80;
 TRISB=0X00;
 PORTB = 0X00;
 TRISA=0X00;
    PORTA=0X00;
    ANSELH=0x00;
 ADCON0 = 0b00000000;
 ANSEL = 0b00000000;
 Timer1_Interrupt();
    LED=0;
//Below code make Ton and Toff time in equal Interval
void interrupt isr(void)
    if(TMR1IF==1)
                    //EA60=45ms CB20 =107ms
             TMR1H=0xEA; //load the time value(0x0BDC) for 100ms delay
    TMR1L=0x60; //Timer1 Interrupt for 65000
    TMR1IF=0; // Clear timer interrupt flag
          Dgt++;
             if( Dgt>=10)
                   // LED = !LED;
void Serial_1_Init()
  BAUDCTL=0b01001000; //16bit baudrate has used
    RCIE=1;
 RCIF=0;
     CCP1IE=1;
    RCSTA=0b10010000;
    SPBRG = 0x81;
    SPBRGH= 0x00; // 9600 Baud Rate for 64Mhz
void EUSART_Initialize(void)
    // disable interrupts before changing states
    RCIE = 0;
    TXIE = 0;
    BAUDCTL=0X09; //16bit baudrate has used
    // SPEN enabled; RX9 8-bit; CREN enabled; ADDEN disabled; SREN disabled;
    RCSTA = 0x90;
    // TX9 8-bit; TX9D 0; SENDB sync_break_complete; TXEN enabled; SYNC asynchronous; BRGH hi_speed; CSRC slave;
    TXSTA = 0x22;
    SPBRG=81;
SPBRGH=00;
RCIE = 1;
void main(void)
             Init_Controller();
            Serial_1_Init();
       //UART_Init(9600);
      /* GIE=1;
     PEIE=1;
     TMR1IE=1; */
  while(1)
        LED =1;
        DelayMs(250);
       Send_string_uart1("hello");
        LED =0;
        DelayMs(250);
Your baudrate calc is slightly wrong,
should be,
SPBRG = (20000000UL/(long)(64UL*(baudRate-1))); // baud rate @20Mhz Clock
You also don't include your config values so you may be using the internal clock.
Ian Rogers
I always use the TXIF to know when to send the next char and have not experienced any problems. Can you elaborate?
datasheet said:
TXIF is also not cleared immediately upon loading TXREG,
but becomes valid in the second instruction cycle following
the load instruction. Polling TXIF immediately following a
load of TXREG will return invalid results.
Meaning if you load the txreg at the point the TXIF is set, sometimes it doesn't shift in correctly!!
I use Radio's and I need to ensure transmit is done...
I've learnt something new, missed that in the datasheet. I guess I've never been bitten because I check the flag before writing rather than directly after.
If you look through the source that comes with C18, that's how its done...
