The magnetic coil ONLY works for CRTs as the electron beam is deflected magnetically.
That's not what deguassing cpoild do though
It's nothing to do with CRT's been magnetically deflected (even though they are), it's to do with the shadow mask, a thin sheet of metal full of holes that makes sure each beam only hits the correct coloured spot on the front.
If this sheet gets magnetised, it bends, and this makes the beams hit the wrong colours - because the metal is so thin (and full of holes) even the earths magnetic field causes it, try rotating a TV while it's ON.
You can use a soldering gun.
A standard technique in the distant past (for when you hadn't got your deguassing coil), but aren't soldering guns long gone now?.
If you cannot get ahold of a degaussing coil you could try a small magnet and carefully bring it close to the problem spot, swirl it around and slowly remove it. This has been known to work but not nearly as effective as a degaussing coil.
Still widely available here in the states.... in fact I have a dual heat range, 325 watt model that I sue often.... you know like when a tin coffee can rips open or the truck frame develops a crack needing repaired!! LOLA standard technique in the distant past (for when you hadn't got your deguassing coil), but aren't soldering guns long gone now?.
