2PAC Mafia
Hi guys,
I know this question is too general but I want to see if I get some good idea.
There is an equipment which is a CAN bus dedicated monitoring unit with screen and always fails on same way, after around 10 years it start failing in this ways:
- Sometimes it is resetting
- Sometimes it switches off and not powering on again after long time
- Sometimes lines on screen and freeze
- Sometimes error message on screen and reset
The problem always come from a pluggable processor board on top of motherboard. We have been repairing other old generations of this boards but on this last generation we can´t find the problem.
We have been testing internal power supplies with logic analizer when problem occurs but everything seems OK, we have been reballing 4 BGA chips (processor, flash and 2 RAMS), we have been replacing some chips but we don´t find the problem.
We have some units all with same problem. Strange thing is if you leave a unit which doesn´t switch on for long time without power sometimes when you try again it works for hours or even one or 2 days.
We have been thinking about a problem on PCB design itself but in this case I´m lost...
May be some general light on this issue from your side? They are very expensive so I would like to find a solution.
