Greetings all,
Im having a problem getting any code Ive written to work on a 12F675. Im using PicBasic Pro to compile in the MPLABS IDE. Im also programming threw the USB PicKit 1.
The kit came with a few tutorials that I can get to work(used to verify that the internal clock was indeed running) but I cant get anything I write and compile into HEX to do anything. Ive tried simple:
loop:
High 1
Pause 1000
Low 1
Pause 1000
Goto loop
or
loop:
GPIO.1 = 1
Pause 1000
GPIO.1 = 0
Pause 1000
Goto loop
and a few other simple variants and cant get an led to light. My leds polarity is correct, also the tutorial programs do alot of things with 8 leds on the evaluation board that all work properly.
Ive configured the compiler and MPLAB as stated on their site so Im guessing that I dont have something inside the IDE right. Ive picked the proper chip, and programmer from the MPLABs drop downlists.
Any help or advice will be greatly appreciated.
<EDITED>
I changed gpio's to pin 1, previously I used 3 as an example but pin 3 is a dedicated input so might cause some confusion
loop:
High 1
Pause 1000
Low 1
Pause 1000
Goto loop
or
loop:
GPIO.1 = 1
Pause 1000
GPIO.1 = 0
Pause 1000
Goto loop
<EDITED>
