Transformer question
Electronman
Hell Guys,
What's the difference of wounding the secondary wires of a transformer at:
1: when the wires are wound clockwise and while they are wound anticlockwise, if you know what I mean?
Is there any difference while we are wounding them?
Is that any thing to do with Flux and Voltage polarity in the secondary? What about causing heat?
There is no difference other than the relative polarity of the output versus input voltage. And that makes no real difference since you just can just reverse connections to one of the windings to reverse the relative polarity anyway.
Typically I believe all windings are wound in the same direction since it likely mechanically simplest to do it that way.
Polarity means phase, that's important in some applications.
Thanks,
But I have heard that maybe it makes difference because when we put a load across the reverse secondary winding then maybe the flux infulances on the primary flux and causes heat and more current draw?
SO you are saying that there just will be an phase difference of zero when both primarry and secondary wires are clockwize and a 180 degrees phase difference when they are anticlockwize, Right?
Could you please provide a reference from where you've heard this?
You will need to provide more information before I (we I think) can make sense of that. I heard this from someone is not math.
Hell Guys,
I was wounded once. I still have the scar. Nyuk!
The polarity of a winding reverses if you wind the winding in the opposite direction.
I've heard that they wound twansformers in the opposite diwection in Austwawia. I heard that it has something to do with the Coriolis force, a near-field force created by millions of Australian toilets.:rolleyes:
