"the input needs to be at least 26V."
Actually somewhat higher because of the valley in the ripple voltage.
Yes I live in the United StatesJust a little footnote but whatever is built it should be built around existing mains power. A transformer for 220 V mains would not fare to well here in the US. This works better when people include their locations in post. I guess we can assume the poster has 220 Volt mains power?
Ron
Operating down to 0V is not important but I would like it to be close to it like 1.5VThe LM317 will nearly do that.
The maximum current rating is 1.5A but I've had no problems drawing 2A for extended periods of time. the datasheet says the the current limit varies between 1.5A and 3.4A, 2.2A is typical but don't bet on it. The current can also be boosted by adding another transistor or more.
The current limit is fixed between 1.5A and 2.2A but can be made adjustable by adding a couple transistors.
The minimum voltage setting is 1.25V but it can be reduced to zero using a band gap reference or an op-amp.
https://www.electro-tech-online.com/custompdfs/2010/03/LM117-1.pdf
It depends on what you want.
How important is:
Operating down to 0V?
Having an adjustable current limit?
Being able to supply 2A rather than 1.5A?
As previously mentioned, it's possible to do all of the above, with additional components.
I do want adjustable current limiting
1.5A is fine it does not have to be 2A
And it does not have to go all the way to 20V but I would like at least 12V
I said "I do want adjustable current limiting"![]()
I looked at the data sheet and it shows it a dual 115/220 primary that I would could just hook up the 115 part, and it has a center tapped secondary which I could just bypass by putting my outs and the top and bottom of it and having nothing attached to the center right?
