list p=16f874a
#include <p16f874a.inc> ;
__CONFIG _CP_OFF & _WDT_ON & _BODEN_ON & _PWRTE_ON & _RC_OSC & _WRT_ENABLE_ON & _LVP_ON & _DEBUG_OFF & _CPD_OFF
;***** VARIABLE DEFINITIONS
w_temp EQU 0x7E ; variable used for context saving
status_temp EQU 0x7F ; variable used for context saving
ORG 0x000 ; processor reset vector
clrf PCLATH ; ensure page bits are cleared
goto Main ; go to beginning of program
ORG 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
Init
clrw ; Zero.
movwf PORTB ; resets input/output ports
bsf STATUS,RP0 ; Select Bank 1
movlw b'00000000' ; Set port B bits as outputs
movwf TRISB ; Set TRISB register.
bcf STATUS,RP0 ; Select Bank 0
retlw 0
Main
call Init
loop
bsf PORTB,0 ;turn on the red light
bsf PORTB,1 ;turn on the green light
goto loop
END
swapf w_temp,f
Init
clrw ; Zero.
retlw 0
Main
call Init
loop
goto loop
END
