Traffic Light for pic 16f874a not working
henrock
list p=16f874a
#include <p16f874a.inc> ;
__CONFIG _CP_OFF & _WDT_ON & _BODEN_ON & _PWRTE_ON & _RC_OSC & _WRT_ENABLE_ON & _LVP_ON & _DEBUG_OFF & _CPD_OFF
;***** VARIABLE DEFINITIONS
w_temp EQU 0x7E ; variable used for context saving
status_temp EQU 0x7F ; variable used for context saving
ORG 0x000 ; processor reset vector
clrf PCLATH ; ensure page bits are cleared
goto Main ; go to beginning of program
ORG 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
Init
clrw ; Zero.
movwf PORTB ; resets input/output ports
bsf STATUS,RP0 ; Select Bank 1
movlw b'00000000' ; Set port B bits as outputs
movwf TRISB ; Set TRISB register.
bcf STATUS,RP0 ; Select Bank 0
retlw 0
Main
call Init
loop
bsf PORTB,0 ;turn on the red light
bsf PORTB,1 ;turn on the green light
goto loop
END
this is the schematic
tradd-jpg.48413
You should make it a habit of putting
 tags around your program code so that the spaces and tabs are intact.
Highlight your code and select the [B]#[/B] button just above the message box.
You should also mention what the code is [I]supposed[/I] to do as well as what it [I]currently[/I] does.
[CODE]list      p=16f874a
		swapf   w_temp,f
Init
        clrw                 ; Zero.
        retlw 0
Main
        call Init
loop
        goto loop
        END
What's the purpose of the interrupt? It looks like this was some sort of learning exorcise about interrupts and context saving.
The rest of the code just toggles two outputs HIGH and LOW really fast since it has no delay.
Thats the default code from the template or example files.
        //ADD DELAY
        //ADD DELAY
