Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Hi..
I am trying to simulate a Totem pole Boost PFC circuit using GaN switches on LTspice. I am unable to achieve the DC output and the circuit is also not boosting up the input voltage. Any suggestions to make my circuit work will be a great help. I have attached my circuit here.
can you explain how the circuit is meant to work? Few of us understand how GAN fets work. The transformer made up of L4 and L5 seems to be working (I expect a turns ratio of root(5). The cathodes of D2 and D4 should surely have an ac signal between them? You have got them shorted out. Could this be the reason?
you seem to have ideal transistors that may cause your simulation to exceed ??? energy conservation laws or simply hang . . .
other than that inside >> GaN_LTspice_GS66516T_L2V2.lib :: *** - - - - - - - - - - - - ↓ - - such models (where you use node voltage read e.g V(+node,-node)) require extra care to do anything with (not that achieving it would be impossible) ... bdtemp 0 TJ I = (if(v(drain,source)>0,
+ (cur*(0.8*PWR((v(TJ)-25+273)/300,-2.7))*log(1.0+exp(26*(v(gate,source)-(7.9+0)+6.2-0.000*(-25))/slp))*
+ v(drain,source)/(1 + max(x0_0+x0_1*(v(gate,source)+4.1),0.2)*v(drain,source)))*
+ v(drainin,sourcein),
+ (cur*(0.8*PWR((v(TJ)-25+273)/300,-2.7))*log(1.0+exp(26*(v(gate,drain)-(7.9+0)+6.2-0.000*(-25))/slp))*
+ v(source,drain)/(1 + max(x0_0+x0_1*(v(gate,drain)+6.1),0.2)*1.0*v(source,drain)))*
+ v(sourcein,drainin)))
* *** ... it is mainly coz the integral continuity of the device "physics" as when there's fast parameter polarity change from say +1V to -1V -- the model must cover the events as if this skip "smoothly" went through the ±Zero Volts . . . - - - . . . which might be impossible if such would also significantly alter the external circuit that lays outside the model(-'s scope) . . .
it may be this it's not a problem here . . . (just a potential one) ???
this seems like a complex task (- a lot of work before you can expect) to achieve anything
so it's better for you to start from simulating each component and/or a functional block on it own first
to get acquainted with their specific Spice behavior (or whether they do simulate in a first place .... there're some op-amp models that seem to have a "backup battery" built in - so you could power an entire grid from them ???)
The circuit is meant to work like an AC-DC boost converter (like in a bridge less boost PFC) here the 2 GaN FETs switch complimentary at 100 KHz and the two Mosfets M1 and M2 switch complimentary at line frequency (as the rectifying switches). The diodes D2 and D4 (the bridge) are used for bypassing the inrush current and charge the bulk cap in the first cycle. I see the inductor current going very high upto 400A which should be even after adding the bypass diodes.
-- U2,M2 . . . U2 won't close no matter the "point" G_H does +
+ PC817B opto has max transition frequency 80 to 135 kHz and that with 50% (or -50dB 3%) output !!! in addition to this 190µH -- you obviously didn't plot the Nitrofets side ...
Hi..
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
