Sorry again for my ignorance but you said this...
To my simple mind, I don't think you should hook up to the existing wires of the toroid. The video shows him having 2 bare toroid "forms" and winding a new one over them. I've even seen some chokes wound on a plastic core a so called 'air core'.
Was that a joke? With my limited knowledge base I sincerely thought you were giving me genuine advice, not sending me on a snipe hunt. Now I really feel stupid after spending a half hour looking for that. At my age, every half hour is valuable!
In my attempt to make a good decision I also came across a site for professional welders and apparently this mod is well known and has been used for at least 10 years with hundreds of forum posts on this subject dating to 2009 so they have practical knowledge. They were getting parts from Radio Shack! So, I am not just trusting some guy on youtube. I'm just trying to build up enough background knowledge to make an informed decision so your site has been invaluable. Thanks again. Call me crazy but I like to tinker so doing stuff like this is fun for me but may not be appropriate for a site like this.
They say stuff like...
The inductor is needed on the output, if you don't have one, it is like welding with car batteries.
I can measure the one on a small Hobart welder, but how you would measure and translate it to what you have ?
You might look for inductors added to batteries for some ideas.
_______________________________________________________________________________________
I did try the welder with and without the choke. Before I wired the choke in permanently I tried welding with it in series with the ground lead. It definitely made a difference. It reduced spatter and made for a less chaotic weld. By that I mean that things ran "smoother". I am able to create and maintain a puddle easier than without the choke. I think more inductance would be good but I was constrained by size. Could only fit so many wraps on the core. Nevertheless having what I got in there is a big improvement to not having it at all.
__________________________________________________________________________________________
Tried it today. Much better than before, but found that I have to cut the wire right at the exit of the torch. This gives a short delay before the wire makes it to the workpiece, giving the cap time to charge. Otherwise, it just sticks to the workpiece and doesn't start arcing. Did a ~2.5" bead without hitting overload. A lot less sputter and better penetration.
______________________________________________________________________________________________
Re: 90A Flux-Core Welder conversion to DCEN - Redux
This is my DIY choke. 23 turns of 8AWG stranded wire THHN on a transformer core from a 1200W microwave. Measured out as 1.4mH. As I mentioned above, as a newbie welder using a bottom-of-the-line welder, I was finding it virtually impossible to do a fillet weld. After the mod my very first try at a fillet weld using 1/8" mild steel was 10X better than anything I had done before (not saying much, I know). Note that this first fillet weld passed the "sledge hammer weld test" with flying colors.
