Tools Calculators.
Hi again,
Eric:
Oh that's great. But any reason why the current is now limited to 0.75 amps? Before it was 1.5 amps.
tmtech:
It's nice to know you tested these that much. I ran one hot a few years ago but never measured the case temperature. It always worked well though. I used it for simply regulating and adjusting the fan speed of a small DC fan.
Interesting article too, and they even mention Bob Pease and the LM337.
Pssd...not tcmtech. tvtech :p
Regards,
tvtech
Regards,
tvtech
Hi again,
Yeah hit the 'm' instead of the 'v', so i typed tmtech (but not tcmtech)...apologies :-)
And it is fixed now...
It's about time you posted these in the tools section, I suggested that you do that eons ago. :p
hi Mike,
I had to learn javascript, html and php coding first also ask EM to allow me access to the site software before I was able to do that.:rolleyes:
If you have any suggestions for more tools/calc's please let me know.
Eric
OT:
Long time no see, hope you are well.
I was sorry to hear of your recent sad loss.
The two circuits for 555 timers show VR1 that feeds the discharge pin, can be adjusted down to 10ohms. With a 12V supply that would almost certainly pop the internal pull-down transistor for that pin.
I would expect the user to have read thru the datasheet, however taking your point I have made the minimum setting as 100R.
Thanks for the input
E.
You don't seem to have a resistive voltage divider calc?
Ie; you input Vin and desired Vout and it tells what two value resistors are needed. It's a simple task for many, but is the kind of thing that newbies stumble with.
Also there are TWO versions there of LM317 calculators!
And using an LM317 as a current regulator is very common, even though it's just one resistor that sets the current limit maybe thats worth doing as a calc.
Ummm, is the chip in your 3915 tool supposed to be a 3914? That's what it shows.
Well spotted Capt.. its now fixed.
Many thanks... you must have a high power telescope to see that error from Uranus...:rolleyes:
Eric
Hello again,
Eric:
The LM317 calculator only goes up to 0.75 amps output now, what happened to the 1.5 amps output?
Hi Eric
I really like what you have done with the LM317 calculator. From practical use and reading temps etc. over Three years, I reckon you are bang on target :).
Great tool.
Best regards,
tvtech
(3915 tool) Not being picky, but there's still two more. Noobs might get confused. Watts box, top half & PS volts, second half. BTW, I occasionally come back to Earth, right about when my beer is gone! And thanks for the cool tools!<ckd>
I would appreciate any positive feedback and suggestions for this new tool.
Its purpose is to give students an insight into what the effect of changing component/parameter values will have on a 'general purpose' voltage regulator circuit.
https://www.electro-tech-online.com/tools/PSUCapV1.php
E
Hi Eric
I like :D:D:D
Played around with it for a while trying different drop out Voltages, Currents etc and all looks good.
Regards,
tvtech
