To shift dc offset sine wave
vrvrao
Hello every one,
I have an sine wave of -15v to 15v ( dc-offset is 0 v) and i need to shift it to a sine wave of 0 - 3v with dc offset of 1.5v.
i taught of using diodes but its cutting off the negative half.
as am new in to electonics,So i dont know much about it.
It would be very helpfull for me if u can give some ideas.
thanks
Its possible to do that using a simple operational amplifier circuit.
It would help you could tell us more about the project, whats the source of the +/-15Vsine and whats the +/-1.5Vsine wave going to be used for.??
hi ,
thanks for reply.
+/-15v supply is from inverter and 0- 3v voltage is to fed controller after converting to pulse.
can you tell me abt the op-amp ckt.
This circuit will do what you ask.
E.
EDIT:
What are the details of the pulse you require.?
can we use lt1632 op amp and can we use 28 v supply voltage for the same ckt.
the pulse required is same 0 - 3v with freqency of 2khz.
The LT1632 looks ok.
You could get a 0/3V square wave directly from a comparator, no need for a level shift stage.
i have an doubt, can we shift the sine wave without adding an voltage reference like V+ at input.
Thats not easily done.
The voltage reference is only the same +5V as the supply to the OPA.
I am not completely sure what you are asking here, but yes it is possible to raise a sinewave so that it is always above 0v but still a sine shape.
Have a look at my attached sketch.
You could also make the sinewave completely negative by reversing the diode.
There are limits to this technique,
there will be a little bit of offset about one diode drop (0.6v), which may not be a problem depending on what you want to use the signal for.
Also, if you want to use this signal as a clock for something, you will have to use something with a Schmitt circuit or a comparator as Eric has suggested in order to give a fast rise time to the clock. Otherwise you may get some strange effects due to noise and the slow risetime of the sinewave.
