Timed voltage controller
krisc
This is my first post here.
I have a very basic knowledge of eletronics.
I'd lik to know if there is a such a device that will take an input voltage (DC) and when pulsed once it will increase it's output voltage from 0v to 12v's then back to 0v again over a set period of time ie: 4sec's (2up-2down)
Is this possible?, the voltage increase and decrease must be smooth and linear.
Any advice/suggestions would be most appreciated :)
[scratch suggestion about using a one-shot - didn't see smooth and linear requirement]
I am not aware of anything on the commercial market, but to design and build one by me would not be very difficult. A Lot depends upon the load of the 12V supply. In other words if the variable voltage has to supply a certain amount of current, it may be a little more complicated.
This will depend on how basic your electronics skills are, but this is a circuit that I built to generate a slow triangle wave (0V-5V). The output is actually 256 "steps" from minimum to maximum voltage. With an RC filter on the output, you could produce a smoother ramp.
What are you trying to do?
Ken
  • Triangle Generator.pdf
