Ok, I am trying to get good sensitivity for a full 360 degrees. the problem is that the sensors available (x,y) loose their sensitivity and the z axis sensors responds to tilt in both directions. I am using the mma1260 and mma2260 sensors.
So what I want to do is mount two x axis sensors perpendicular to each other. The problem is the securing of a small pcb at a right angle to the main pcb. what parts can i use to securely fasten a pcb at a right angle and allow for signals (analog and power) to reach the main pcb?
