This might be more of a physics question than an electronic one but...
The usual first-year electronics theory refers to the charge on a capacitor being stored on the plates. But, even a fairly cursory look at the formula for determining a capacitor's capacitance indicates that the dielectric constant of the insulator plays as big a role as the plate area and spacing.
The explanation then given is that the charge is actually stored in the dielectric (by essentially stressing and distorting the atoms) and the plates are merely used to provide conductive surfaces to distribute the charge between the dielectric and the campacitor's leads.
Okay, good enough. But, I guess the part I don't get (assuming I "got" the other part right) is how the atoms in the dielectric distort. It can't be that electrons are drawn through the dielectric because the better insulator the dielectric is the more capacitance it can give. Are the orbits of the electrons somehow distorted? Is there some sort of quantum action going on? Is the stress concentrated on the surfaces of the dielectric or is it distributed across the thickness of the dielectric?
An ancilary question might be: What is it about a good insulator (atomically speaking) that makes it a good dielectric in the first place (beyond the obvious, "because it effectively resists the flow of electrons").
My math is lousy and you'll notice I've used no formulas or equations and hopefully there's a reasonable explanation to this that doesn't need them...otherwise, to be quite frank, I'll be lost.
