I have a relic D61 from the 70's, its mainly used for iffy jobs on high voltages so I dont blow up my newer philips I recently aquired.
The trigger circuit stopped working, and using my other 'scope and a sig gen I traced the problem to the trigger amp, one of the transistors wasnt making connection in its socket, so its now soldered direct.
The trigger still isnt good on certain ranges, it'll trigger ok for a second if I move the trigger switch from normal to tv and then back again for a second or so then fail, most of the ranges work ok, I think maybe a cap is leaking or breaking down or maybe the h timebase switch is bad, I've cleaned it a couple of times.
Another issue that concerns me more is if you turn up the brightness past a certain point the displayed image gets bigger as if you just increased the input signal, I'm thinking maybe power supply issue, the caps are original.
This thing probably should go in the skip however it has it uses and there is some sentimental value, my mrs bought it for me a while back
