I am trying to make task manager in program that looks for all task's and decide which one task will be run next . Timer interrupt should be keep the track of system time
Let's say we have eight task's. 1-6 are dead task's and 7 and 8 are active task. Task 7 start and stop for every 250 ms and Task 8 start and stop for every 500 ms
In my code interrupt happens at every 10ms
Pommie Ian Rogers , any idea would be apricated
C:
#define _XTAL_FREQ 8000000
#include <xc.h>
// PIC18F45K80 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config RETEN = OFF // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = HIGH // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
#pragma config XINST = OFF // Extended Instruction Set (Enabled)
// CONFIG1H
#pragma config FOSC = INTIO2 // Oscillator (Internal RC oscillator)
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = OFF // Power Up Timer (Disabled)
#pragma config BOREN = SBORDIS // Brown Out Detect (Enabled in hardware, SBOREN disabled)
#pragma config BORV = 3 // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1048576 // Watchdog Postscaler (1:1048576)
// CONFIG3H
#pragma config CANMX = PORTB // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
#pragma config MSSPMSK = MSK7 // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K // Boot Block Size (2K word Boot Block size)
// CONFIG5L
#pragma config CP0 = OFF // Code Protect 00800-01FFF (Disabled)
#pragma config CP1 = OFF // Code Protect 02000-03FFF (Disabled)
#pragma config CP2 = OFF // Code Protect 04000-05FFF (Disabled)
#pragma config CP3 = OFF // Code Protect 06000-07FFF (Disabled)
// CONFIG5H
#pragma config CPB = OFF // Code Protect Boot (Disabled)
#pragma config CPD = OFF // Data EE Read Protect (Disabled)
// CONFIG6L
#pragma config WRT0 = OFF // Table Write Protect 00800-01FFF (Disabled)
#pragma config WRT1 = OFF // Table Write Protect 02000-03FFF (Disabled)
#pragma config WRT2 = OFF // Table Write Protect 04000-05FFF (Disabled)
#pragma config WRT3 = OFF // Table Write Protect 06000-07FFF (Disabled)
// CONFIG6H
#pragma config WRTC = OFF // Config. Write Protect (Disabled)
#pragma config WRTB = OFF // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF // Data EE Write Protect (Disabled)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protect 00800-01FFF (Disabled)
#pragma config EBTR1 = OFF // Table Read Protect 02000-03FFF (Disabled)
#pragma config EBTR2 = OFF // Table Read Protect 04000-05FFF (Disabled)
#pragma config EBTR3 = OFF // Table Read Protect 06000-07FFF (Disabled)
// CONFIG7H
#pragma config EBTRB = OFF // Table Read Protect Boot (Disabled)
volatile char tick_flag = 0; /* if non-zero, a tick has elapsed */
// port pin Initialization
void Port_pins_Initialized (void)
LATA = LATB = LATC = LATD = LATE = 0;
TRISA = 0b00000000;// all are output, Unused
TRISB = 0b00000000;// all are output, Unused
TRISC = 0b00000000;// all are output, Unused
TRISD = 0b00000000;// Eight LEDS connected
TRISE = 0b00000000;// All are output, Unused
ANCON0 = 0; // digital port
ANCON1 = 0; // digital port
CM1CON = 0; // Comparator off
CM2CON = 0; // Comparator off
ADCON0 = 0; // A/D conversion Disabled
// Timer0 Initialization
void Timer0_Initialized (void)
TMR0L = 176; //Timer0 Register Low Byte
//TIMER0 CONTROL REGISTER
TMR0ON = 1; //Timer0 On
T08BIT = 1; // Timer0 is configured as an 8-bit timer/counter0
T0CS = 0; // Internal instruction cycle clock (CLKO)
T0SE = 1; //Increments on high-to-low transition on T0CKI pin0
PSA = 0; //Timer0 prescaler is assigned; Timer0 clock input comes from prescaler output
//1:256 Prescale value
T0PS2 = 1;
T0PS1 = 1;
T0PS0 = 1;
//INTCON: INTERRUPT CONTROL
PEIE = 0; //Disables all peripheral interrupts
TMR0IE = 1; //Enables the TMR0 overflow interrupt
INT0IE = 0; //Disables the INT0 external interrupt
RBIE = 0; //Disables the RB port change interrupt
TMR0IF = 0;// cleared timer overflow flag
INT0IF = 0; // disabled external interrupt
RBIF = 0; //disabled Port Change Interrupt Flag bit
GIE = 1; // Enable Global Interrupt Enable bit
// Interrupt service routine
void __interrupt(high_priority) tcInt(void)
if (TMR0IF == 1) // Timer0 overflow interrupt flag bit
tick_flag = 1;
TMR0IF = 0;
void task_manager(void)
char task;
task=0;
switch(task)
case 0:
task0();
break;
case 1:
task1();
break;
case 2:
task2();
break;
case 3:
task3();
break;
case 4:
task4();
break;
case 5:
task5();
break;
case 6:
task6();
break;
case 7:
task7();
break;
default:
break; /* no task was active!! */
//Main program start from here
void main(void)
Port_pins_Initialized (); // port pin initialization
Timer0_Initialized (); // Timer initialization
while (1)
if (tick_flag == 1)
tick_flag = 0;
