Switches convert to NC
I thought i saw something on the web once where a transistor was used to convert a normaly open switch to normanal closed switch or is the any way to do this w/o a relay?
Just in case i didn't explain it correctly, I need a a pushbutton switch that stays open when pushed.. so, I think that is a "normal open switch"
thanks any help will be great.
... I need a pushbutton swith to work where if it's pushed the light turns on and if you let go the light will turn off.
That is not a normally closed switch, that is a plain normally open switch and needs nothing else than a 'momentary pushbutton switch' from any electronics store.
+--------------./ .----------------load--------------gnd
Like a doorbell pushbutton switch.
Miguel
You could use a relay with NC contacts but you're better off just buying the correct switch.
Miguel
Actually i need a a pushbutton switch that stays open when pushed.. so, I think that is a "normal open switch"
Would it work with a transistor?
Please post as schematic so we can see the bigger picture.
those radio shack pushbutton switches dont' work as NO. where current flows through them when released only when pushed.
but i think i found a solution:
I had to buy switches both N/O and N/C of the same type. I got them both as four-switch packs at Radio Smack. They called yours out as normally-closed in their catalog, but fail to label the normally-open as such.
Here you go:
Mini SPST 0.5-Amp Momentary Switch (4-Pack) - RadioShack.com
These are what you want, at RShack. They are the same cheap failure-prone junk as your first find. BTW, the red and black plungers don't indicate which type you are using, both packs have two red and two black. Use labels!
Take care,
kenjj
Here you go:
Take care,
kenjj
Ok So I found another switch but just so you know for future reference those switches are NC switches there were zero NO type switches.
