Superimpose Images
Ramussons
Active Member
Hi all,
I have a photo of the track side of a PCB which has been flipped as to view then track thru' the board.
I have another photo of the component side of the same PCB.
Is there a way of super imposing one over the other so that the circuit diagram can be easily traced?
Thanks,
Ramesh
Hi all,
Thanks,
Ramesh
hi Ramesh,
I use Paint Shop Pro.
Load all the pcb images into PSPro
Select and copy an image , flip or mirror, then paste as a 'transparent selection' onto another image.
Do you follow OK.
If you get stuck post your images and I will try to edit them as you ask.
E.
Any freeware?
Almost any graphics editing software should be able to do something similar. What do you have available?
Free programs: Irfanview + Windows Paint
Irfanview can be used to do the thresholding to convert the tracks to black/white and set the transparency (not actually required). Windows paint can then be used to overlay the tracks in the manner mentioned by Eric above
Thanks alec_t and dougy83.
I have Irfan View. I'm running Win XP SP2 and the windows paint does not support layers.
I'll try GIMP 2.
Ramesh
Windows paint can paste with a transparent background colour. GIMP should certainly be able to accomplish it as well.
Irfanview can also superimpose images. Go to Edit/Insert overlay. You can set the overlay transparency.
I didn't know that. Unfortunately you have to specify offset coordinates. It's easier in paint as you can drag the overlay around and resize it until it fits.
