stud mount Schottky diodes
gretone
hello everyone, I am looking for stud mount Schottky diodes for a 250watt amp I have to make it a class A amp, they are in the output stage, the diode are missing from the boards, I have the schematic for the amp but there is no identification for the diodes, all advice is welcome.
thank you
rob
hi zapper ,
please let me know if this is what you need,
and thank you both
kind regards
rob
Well this is a strange circuit? - what are the diodes doing?, and what are R67 and R68 doing? - and how do they survive, 2.7 ohm 10W resistors that appear to have 80V across them? (almost 3KW dissipation).
Presumably the OP is aware how hot class A amps run?, and will be massively increasing the cooling - although I'm a bit puzzled why he would want to make it class A?.
Hi ,
SAE, made a 250watt 01 series amp & a 250watt X series class A, Hypersonic amp, both amps are physically the same, ( I have two 250watt 01 amps ) But, one of them has the X series boards in it. both amps are rated at full power down to 2 ohms without forced air cooling as they have very large heat sinks like the Krell amps.
so, I thought I would try and get parts to make it a class A amp,
The parts I need are as follows :
Q15 X 2, Toshiba 2SD845 & Q16 X 2, Toshiba 2SB755
R67 X 2 & R 68 X 2
CR14 X 2 & CR 15 X 2 ( there is no identification for these stud mount Schottky diode ) My knowledge does not
extend enough to work out the which Schottky diodes I need,
At the time, SAE was using up there inventory before they sold the company, That is how I have a 01 amp with the X boards in,
All involved in helping me is greatly appreciated ,
Thank You
Kind Regards
Rob
