Resource icon
Strobe light 2010-07-06
ElectroMaster
Administrator
ElectroMaster submitted a new article:
Strobe Light - Strobe lights are widely used by disco lovers to create wonderful visual effects in disco halls and
Strobe lights are widely used by disco lovers to create wonderful visual effects in disco halls and auditoria. The circuit of a battery operated portable miniature strobe light, which can be constructed using readily available inexpensive components, is described here. For convenience and simplicity, an ordinary neon lamp is used here in place of the conventional Xenon tube. The whole gadget can thus be easily accommodated in a small cabinet, such as a mains adaptor cover, with a suitable...
Read more about this article...
I don't know if you realize but you labelled the transformer wrong. The side where the power is being supplied from is always the primary. If you were using it to step down the voltage then it would be the opposite way around and the coil with more windings would then be the primary, you labelled it entirely backwards.
