Strange I/O hearbeat every 2 seconds with PIC16LF15313 ...<SOLVED>
Beau Schwabe
Active Member
Here is a strange one I can't quite seem to pinpoint. At first I thought it was the Watchdog timer, and then possibly an Interrupt, but neither one of those seem to be causing a 2ms pulse every 2 seconds.
I have reduced the code down to a bare minimum and still see the issue (See scope images)
Also moved the power supply to battery power and it is still present.
Any thoughts would be welcome
#include "p16lf15313.inc"
CONFIG1 = _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
CONFIG2 = _MCLRE_OFF & _PWRTE_OFF & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_ON & _STVREN_ON
CONFIG3 = _WDTCPS_WDTCPS_31 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_SC
CONFIG4 = _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTSAF_OFF & _LVP_ON
CONFIG5 = _CP_OFF
    org        0
    goto    Init
    org        100
Init:
    banksel LATA
    movlw   b'00000000'
    movwf   LATA
    banksel TRISA
    movlw   b'00000000'
    movwf   TRISA
    banksel LATA
    bsf    LATA,2
Main:
    goto Main
    end
Nothing else connected ... I program with a PICkit 3 ... but I removed it from that. It's just on a Solder less bread board right now. I was doing some proof of concepts for a project and noticed the behavior.
Have you tried a different chip?
BTW, what is LPBOR - Low Power Brown Out Reset?
Mike,
I just programmed a second micro and it's the same thing. All I have is power and ground connected... scope is on pin 5 with a shared ground. Scope is galvanically isolated.
Yes - "LPBOR - Low Power Brown Out Reset "
Got me stumped. Have you checked for an errata sheet?
As for LPBOR, I was asking how it differed from normal BOR? They appear to be the same.
Yeah, I've been programming for years, and this is a first, however this particular PIC micro is new to me. On any othe micro, the code just works.
Have you checked that it definitely isn't being reset. I think I have some of these at home (in school atm) so may be able to play with this later.
Something wrong here. The LF series is supposed to run 2.0 to 3.6V according to the datasheet, but your scope captures show 5V P-P.
So is it just the "F" series, or the LF" as your title states?
Other suggestion, if nothing connected, and different chips show the same, then is it the power supply? Try another...
I second the suggestion of the power supply. Or, better yet, check if you have a short circuit. We Lost a little clipping of a resistor into a breadboard and caused a short. Most newer smps will "hiccup" to stay below current limit when they are connected to a short. They cycle at about 1 or 2 seconds until they hit current maximum and then cut out again. They, in 1 or 2 seconds, they try again.
Sagor1,
Dang, I thought you might have been onto something I missed. I lowered the voltage to 3V and then to 2V on a 3rd micro (to make sure I didn't damage it in the first two attempts) and still observe the same behavior.
EDIT
Mike, it does actually go into reset (See attached image Channel 2 shows the reset)... Mike, I'm certain it isn't going into reset ... I modified the code just before "Main:" slightly, so that an io pulses HIGH then LOW at the beginning
So why does this code go into reset? Three different micros, and I changed the position on the SBB. There are no shorts, and there is a 10uF cap across pins 1 and 8
;WAS
    banksel LATA
    bsf    LATA,2
    Main:
;IS
    banksel LATA
    bsf    LATA,2
    bsf    LATA,1
    nop
    nop
    nop
    nop
    bcf    LATA,1
    Main:
What happens if you add a watchdog reset in the main loop ??
It could be some kind of device but that means the watchdoc is not disabled when it should be..
SOLVED!
The problem is in the WDT (Watch Dog Timer)
Upon a reset the micro goes into a low speed mode and enables the WDT regardless of what you set the configuration bits to.
The low speed mode is relatively easy to programmatically correct...
    banksel OSCCON1
    movlw   b'00010000'
    ;         X....... Reserved
    ;         .XXX.... OSC Source
    ;         ....XXXX Divider
    movwf   OSCCON1
    banksel OSCFRQ
    movlw   b'00000110'
    ;         XXXXX... Reserved
    ;         .....XXX HFINTOSC Frequency Selection
    movwf   OSCFRQ
Even if you enable the SWDTEN (Software Watch Dog Timer Enable) from the configuration bits, it still seems to have no control
programmatically from the WDTCON0 register to disable it.
    banksel WDTCON0
    movlw   b'00000000'
    ;         XX...... Unemplemented
    ;         ..XXXXX. WDT Prescale
    ;         .......X WDT Software Enable
    movwf   WDTCON0
The "SOLUTION" I found was to set the WDT clock source to any of the 'RESERVED' sources so it simply doesn't increment.
I don't like pointing to a reserved location, but I can't find any way to programmatically dissable the WDT after a reset without having to feed the WDT with a CLRWDT
    banksel WDTCON1
    movlw   b'01110000'
    ;         X....... Unemplemented
    ;         .XXX.... WDT Clock Select
    ;         ....X... Unemplemented
    ;         .....XXX WDT Window Select
    movwf   WDTCON1
Complete TEST CODE below
CONFIG3 = _WDTCPS_WDTCPS_31 & _WDTE_SWDTEN & _WDTCWS_WDTCWS_7 & _WDTCCS_SC
CONFIG5 = _CP_OFF
    RES_VECT  CODE    0x0000            ; processor reset vector
    goto    Init            ; go to beginning of program
    MAIN_PROG CODE                      ; let linker place main program
Init:
    banksel LATA
    movlw   b'00000000'
    movwf   LATA
    banksel TRISA
    movlw   b'00000000'
    movwf   TRISA
    banksel LATA
    bsf    LATA,2
    bsf    LATA,1
    nop
    nop
    nop
    nop
    bcf    LATA,1
    banksel OSCCON1
    movlw   b'00010000'
    ;         X....... Reserved
    ;         ....XXXX Divider
    movwf   OSCCON1
    banksel OSCFRQ
    movlw   b'00000110'
    ;         XXXXX... Reserved
    movwf   OSCFRQ
    banksel WDTCON0
    movlw   b'00000000'
    movwf   WDTCON0
    banksel WDTCON1
    movlw   b'01110000'
    movwf   WDTCON1
    banksel LATA
Main:
    ;bsf    LATA,2
    ;clrwdt
    ;bcf    LATA,2
    goto Main
    end
