I need to implement a counter with count sequence which stores random numbers using verilog and display it on 7 segmentt display. I have no problems in calling the numbers out as a function, but can someone guide me how do I store random numbers using flip flops? It needs to be activated by a "clock".
I have done part of the verilog code, but i know it is wrong because I am not storing any numbers in the flip flop.
module Q1(KEY1,HEX0);
input [1:0] KEY1;
output [6:0] HEX0;
assign CLK = KEY1;
shift_reg (CLK,RESET, 0010,Q);
shift_reg (CLK,RESET, 0001,Q);
shift_reg (CLK,RESET, 0000,Q);
shift_reg (CLK,RESET, 0111,Q);
shift_reg (CLK,RESET, 0011,Q);
shift_reg (CLK,RESET, 1000,Q);
endmodule
// 4-bit Shift Register with Reset
module shift_reg (CLK, RESET, in, Q);
input CLK, RESET;
input [3:0] in;
output [3:0] Q;
reg[3:0] Q;
[email protected](posedge CLK or posedge RESET)
begin
if (RESET)
Q <= 4'b0000;
else
Q <= {Q[3:0], in};
end
display (Q,HEX0);
endmodule
//*****HEX Module*****////
module display (U,HEX0);
input [0:3] U;
output [6:0] HEX0;
assign HEX0[0]=(~U[0]&~U[1]&~U[2]&U[3])|(~U[0]&U[1]&~U[2]&~U[3]);
assign HEX0[1]=(~U[0]&U[1]&~U[2]&U[3])|(~U[0]&U[1]&U[2]&~U[3]);
assign HEX0[2]=(~U[0]&~U[1]&U[2]&~U[3]);
assign HEX0[3]=(~U[0]&~U[1]&~U[2]&U[3])|(~U[0]&U[1]&~U[2]&~U[3])|(~U[0]&U[1]&U[2]&U[3]);
assign HEX0[4]=(~U[0]&~U[1]&~U[2]&U[3])|(~U[0]&~U[1]&U[2]&U[3])|(~U[0]&U[1]&~U[2]&~U[3])|(~U[0]&U[1]&~U[2]&U[3])|(~U[0]&U[1]&U[2]&U[3])|(U[0]&~U[1]&~U[2]&U[3]);
assign HEX0[5]=(~U[0]&~U[1]&~U[2]&U[3])|(~U[0]&~U[1]&U[2]&~U[3])|(~U[0]&~U[1]&U[2]&U[3])|(~U[0]&U[1]&U[2]&U[3]);
assign HEX0[6]=(~U[0]&~U[1]&~U[2]&U[3])|(~U[0]&U[1]&U[2]&U[3])|(~U[0]&~U[1]&~U[2]&~U[3]);
endmodule
