More Coffee
I'm flirting with the idea of putting a power cross feed on my 9x20 bench lathe.
I think a stepper motor would offer more fluid control of the cutting tool.In the end for finer control, the motor will be run at a 4:1 ratio to the cross slide wheel
I would like to put together a system that's variable speed, forward/reverse with a normally off switch.
no microcontrollers or computer interface.. analog manual control through a switch and potentiometer only
So im doing a little research.. Nema 17 motor.
I'm looking at a motor that's rated at 5.32 Kg holding torque and operates 12v..
Does a stepper motor's holding torque represent its shaft torque.
Any recommendations for a simple circuit? Or an avaliable control and power supply?
Everything Im finding requires an interface with some other gadget.
Thanks for listening.
