For the diff amp (which is a balanced bridge circuit with gain), again it is the ratios that matter most.
Must admit I wouldn't consider a differential amplifier a 'bridge'
Oooh... another chance for me to plug one of my favourate circuits?
Perhaps the circuit I use here would be of use - a two transistor phase-shift oscillator with Wien-bridge style amplitude control. It gives THD around 1% is seem to remember.
NG
I've been reading through your ESR meter posted detail .. .. can't see any problem, as you say, much more straightforward.
Are you aware there has been a revised version published in 2004 ? Some variations ... .. some of the obsolete components have been upgraded; only one battery used;
Basically, looks the same to me .. .. any comments ?
Not a lot of use asking then !
Dropping to one battery and removing the bulb make it easy to build, but it's essentially the same project with minor changes.
Basically looks nearly identical to me
