Split Numbers
I didn't know it will automatically link them ... that's cool. I don't want to be a bother but im away from my pc right now and can't check it... how would I make/use externs?
You use extern to define a reference to a variable declared outside of the module.
extern int foo;
in one module, it needs to be declared.
int foo;
any C Reference will give you the details and some PIC compilers do things differently so check the manual.
for some reason i get errors... Some questions:
1. Do i have to include header in each c file?
2. How do i extern a #define?
Can someone show me some examples of this. I hate the c18 manual it sux. No good info in it.
3. Anyone got a better resource than the c18 manual?
If I remember the rest of the thread you are doing separate compiles then linking. If a C file needs info from a header file you have to include the header file. Well written header files have a check in the form of #ifdef myFlagName that will prevent them from generating errors if included twice.
You do not do extern #defines, you include the header file in which they exist.
The things you are talking about are general C related issues. So the BoostC or C18 linker and complier docs would be more helpful. Maybe a general C book like K&R C. Most of what you want is going to be buried in a lot of other stuff. Maybe a section on linking objects would have some of it.
I would like to provide more info but I have to run. Mike or one of the others can fill in the details, if not I will be back in a few hours.
there is no such thing as an extern for #defines. An extern is a message for the linker, #define is actually a preprocessor directive that caused the defined string to textually substituted before the compiler is actually run. #defined names actually don't exist to the compiler itself. By the way, all # lines are preprocessor directives. Even #include...
Take all your #defines and put them in .h files. Separate them into logical groupings - serial I/O ones in serial.h, LCD ones in lcd.h. I would include the function prototypes in the relevant .h. Then #include the relevant .h files in the .c files that reference them. I'd put together a simple example but I've got to go earn a buck...
Thanks a bunch... that seems to make sense.. I mean organizing it. That's the whole reason I want to split it so I can reuse it without issue. Thanks again... I make a buck tommorow.(off today)
here is a pic of it still working on adding 1 more button tho.
btn01 = mode/enter
btn02 = change
btn03 = enter
i want to put enter button seperate lol
picture-008-jpg.22309
lol I will ... I told you I build an expesive clock lol but its a same and since its in C and im bit banging l2C I can port it over easily.
Edit: and use a smaller pic lol. I have the DS1337 on the other side ill take a pic as soon as I get home. Im out getting some breakfast.
here is the full source with some new fixes.
FIXES (major):
When setting time it skipped # 9 (fixed)
When setting time it started @ 0 (fixed to start @ 1)
Added:
"The Time Is:" on line 1 and time on line 2
#include <p18f4525.h>
#include <stdio.h>
#include <delays.h>
#pragma config WDT = OFF, OSC = HS, LVP = OFF
void main(void);
//// Delay Stuff
void delay_s(unsigned char);
void delay_ms(unsigned char);
void delay_us(unsigned char);
//// I2C Stuff
void i2c_byte(char addr);
void i2c_start(void);
void i2c_ack(void);
char i2c_input(void);
void i2c_clock(void);
void i2c_stop(void);
//// RTC Stuff
char rtc_read(char offset);
char rtc_write(char offset, char data);
//// LCD Stuff
void lcd_clr_line(char line);
void lcd_init(void);
void lcd_cmd(unsigned char cmd);
void lcd_char(unsigned char tchar);
void lcd_string(char *);
void lcd_nybble(unsigned char data,char rs);
void e_togg(void);
//// General Stuff
void set_time(void);
void get_buttons(char hm);
//// Variables and Defines
#define SDA_PORT PORTCbits.RC4
#define SDA LATCbits.LATC4
#define SDA_TRIS TRISCbits.TRISC4
#define SCL LATCbits.LATC3
//// RTC Variables
char slave_r = 0b11010001;
char slave_w = 0b11010000;
//// LCD Variables and Define
char Line1 = 0x80;            // 0x80 is the command hex to move cursor to 0 (Line 1 first character)
char Line2 =  0xC0;            // 0xC0 is the command hex to move cursor to 64 (Line 2 first character)
#define lcd_rs LATBbits.LATB4          // define LCD RS - PIN
#define lcd_e LATBbits.LATB5           // define LCD E  - PIN
#define lcd_DB7 LATBbits.LATB0         // define LCD Data Bit 7
#define lcd_DB6 LATBbits.LATB1         // define LCD Data Bit 6
#define lcd_DB5 LATBbits.LATB2         // define LCD Data Bit 5
#define lcd_DB4 LATBbits.LATB3         // define LCD Data Bit 4
//// General Variables and Defines
#define up_btn PORTAbits.RA0
#define set_btn PORTAbits.RA1
//// RTC Variables
char time[9] = " ";
char s_time[9] = " ";
char seconds;
char minutes;
char hours;
char g_hr_high, g_hr_low;
char g_min_high, g_min_low;
char stringA[9] = {'S','e','t',' ','H','o','u','r',0};
char stringB[12] = {'S','e','t',' ','M','i','n','u','t','e','s',0};
char stringC[13] = {'T','h','e',' ','T','i','m','e',' ','I','s',':',0};
void main(void)
    char sec_low, sec_high;
    char min_low, min_high;
    char hr_low, hr_high;
    char tmp,tmp2;
    ADCON1 = 0b00001111;
    TRISC = 0x00;
    TRISB = 0x00;
    TRISA = 0x00;
    TRISAbits.TRISA0 = 1;
    TRISAbits.TRISA1 = 1;
    lcd_init();                             //Launch Initialize function
    lcd_clr_line(0);
    delay_ms(50);
    lcd_cmd(Line1);                         //Set to Line 2
    delay_ms(50);
    lcd_string(stringC);                     //Send our string.
    delay_ms(60);
    while(1){
        for(tmp=0;tmp<9;tmp++){
            time[tmp] = 0x30;
            s_time[tmp] = 0x30;
        time[2] = 0x3A;
        time[5] = 0x3A;
        time[8] = 0;
        s_time[1] = 0x31;
        s_time[2] = 0x3A;
        s_time[5] = 0x3A;
        s_time[8] = 0;
        seconds = rtc_read(0x00);
        minutes = rtc_read(0x01);
        hours = rtc_read(0x02);
        time[7] = sec_low = (seconds & 0x0F) + '0';
        time[6] = sec_high = ((seconds>>4) & 0x0F) + '0';
        time[4] = min_low = (minutes & 0x0F) + '0';
        time[3] = min_high = ((minutes>>4) & 0x0F) + '0';
        time[1] = hr_low = (hours & 0x0F) + '0';
        time[0] = hr_high = ((hours>>4) & 0x0F) + '0';
	    lcd_cmd(Line2);                         //Set to Line 1
        delay_ms(1);
	    lcd_string(time);                     //Send our string.
        delay_ms(50);
        if(set_btn){
            set_time();
            delay_ms(50);
            rtc_write(0x00,0x00);
            s_time[0]-= 0x30;
            s_time[1]-= 0x30;
            s_time[3]-= 0x30;
            s_time[4]-= 0x30;
            tmp2 = (s_time[3]<<4) + s_time[4];
            rtc_write(0x01,tmp2);
            tmp2 = (s_time[0]<<4) + s_time[1];
            rtc_write(0x02,tmp2);
            lcd_clr_line(0);
            delay_ms(50);
            delay_ms(50);
            delay_ms(60);
////            DELAY FUNCTIONS
void delay_s(unsigned char x)
    char var1;
	for(var1=0;var1<x;var1++)
        Delay10KTCYx(500);    //5,000,000 cycles = 1 second
void delay_ms(unsigned char x)
    char var1;
        Delay1KTCYx(5);    //5,000 cycles = 1 us
void delay_us(unsigned char x)
    char var1;
        Delay1TCY();    //5 cycle = 1 us
        Delay1TCY();
        Delay1TCY();
        Delay1TCY();
        Delay1TCY();
////            I2C FUNCTIONS
    SCL = 1;
    delay_us(5);
    SCL = 0;
void i2c_start(void){
    SDA_TRIS=0;   //SDA Output
    SCL=0;        //Clock Low
//Start - 5us
    SDA=1;        //SDA High
    SCL=1;        //Clock high
    delay_us(4);
    SDA=0;        //SDA Low
    delay_us(1);
    SCL=0;        //Clock Low
void i2c_byte(char addr){
    char bl;
    for(bl=0;bl<8;bl++){
        if((addr & 0x80) != 0)
            SDA = 1;
        else
            SDA = 0;
    i2c_clock();
    addr=addr<<1;
void i2c_ack(void){
    SDA_TRIS = 1;   //SDA Input
    i2c_clock();
    delay_us(5);
    //while(SDA);
    SDA_TRIS = 0;
char i2c_input(void){
    char temp;
    char i;
    SDA_TRIS = 1;
    temp=0;
    i = 0;
    for(i=0;i<8;i++){
        temp=temp<<1;
        if(SDA_PORT)
            temp|=1;
        i2c_clock();
    SDA_TRIS = 0;
    return temp;
void i2c_stop(void){
    SDA = 0;
    SCL = 1;
    delay_us(3);
    SDA = 1;
    SCL = 0;
////            RTC FUNCTIONS
char rtc_write(char offset, char data){
    char temp;
    i2c_start();                //Start
    i2c_byte(slave_w);          //Slave Byte
    i2c_ack();                  //ACK
    i2c_byte(offset);           //Address Offset
    i2c_ack();                  //ACK
    i2c_byte(data);          //Slave Byte
    i2c_ack();                  //ACK
    i2c_stop;                    //Stop
    return temp;
char rtc_read(char offset){
    char temp;
    i2c_ack();                  //ACK
    i2c_ack();                  //ACK
    i2c_byte(slave_r);          //Slave Byte
    i2c_ack();                  //ACK
    temp = i2c_input();         //Get Data
    i2c_ack();                  //ACK
    i2c_stop;                    //Stop
    return temp;
////            TIME FUNCTIONS
void set_time(void){
    lcd_clr_line(0);
    delay_ms(100);
    lcd_clr_line(1);
    delay_ms(100);
    lcd_cmd(Line1);                         //Set to Line 1
    delay_ms(100);
    lcd_string(stringA);                     //Send our string.
    delay_ms(100);
    lcd_clr_line(1);
    delay_ms(50);
    lcd_cmd(Line2);                         //Set to Line 2
    delay_ms(50);
    lcd_string(s_time);                     //Send our string.
    delay_ms(60);
    while(!set_btn){
        delay_ms(50);
        if(up_btn)
            get_buttons(1);
    lcd_clr_line(0);
    delay_ms(100);
    lcd_clr_line(1);
    delay_ms(100);
    delay_ms(100);
    lcd_string(stringB);                     //Send our string.
    delay_ms(100);
    lcd_clr_line(1);
    delay_ms(50);
    delay_ms(50);
    delay_ms(60);
    while(!set_btn){
        delay_ms(50);
        if(up_btn){
            get_buttons(0);
void get_buttons(char hm){
if (hm == 1){
    if(s_time[0] == 0x31){
        if(s_time[1] < 0x32){
             s_time[1]++;
        } else {
             s_time[1] = 0x31;
             s_time[0] = 0x30;
    } else {
        s_time[1]++;
        if(s_time[1] > 0x39){
            s_time[1] = 0x30;
            s_time[0]++;
} else {
   s_time[4]++;
    if(s_time[4] > 0x39){
        s_time[4] = 0x30;
        if(s_time[3] == 0x35)
            s_time[3] = 0x30;
        else
            s_time[3]++;
    lcd_clr_line(1);
    delay_ms(50);
    delay_ms(50);
    delay_ms(60);
////            LCD FUNCTIONS
//This is our clear line command.
    char tline;                             //The line to clear variable
    char x;                                 //loop variable
    if(line==0)                             //set the variable value based on line
        tline=0x80;                         // 0 = Line 1
    else
        tline=0xA8;                         // 1 = Line 2
    lcd_cmd(tline);                         // Send command to jump to beggining of line (1/2)
    delay_ms(1);
    for(x=0;x<40;x++){                      // Loop through all 40 chars of line (even tho 16 are viewable)
        lcd_char(0x20);                     // Send Blank Character
        delay_us(500);
    lcd_cmd(tline);                         // Go back to beggining of line
    delay_ms(1);
void lcd_init(void)
{                                       //This is our lcd initialization function
    delay_ms(20);                       // Wait at least 16 mS after powerup
	lcd_nybble(0x03,0);                 // send 0x03 cmd 3 times to initialize
	delay_us(160);
	e_togg();                       // Since 0x03 nybble is on the port already
	delay_us(160);                      // we just toggle 2 more times
	e_togg();
	delay_us(160);
	lcd_nybble(0x02,0);                 //Enable 4 bit mode
	delay_us(160);
	lcd_cmd(0x28);			    //set 4-bit mode and 2 lines @ 5x7
	delay_us(160);
	lcd_cmd(0x10);			    //cursor move & shift left
	delay_us(160);
	lcd_cmd(0x06);			    //entry mode = increment
	delay_us(160);
	lcd_cmd(0x0d);			    //display on - cursor blink on
	delay_us(160);
	lcd_cmd(0x01);			    //clear display
	delay_us(160);
    delay_ms(5);
void e_togg(void){
    lcd_e = 1;
    lcd_e = 0;
void lcd_cmd(unsigned char letter)
//This is our Command Function
//The RS is set to 0 to signify this is a command
	unsigned char temp;             //Our temp Variable
	temp=letter;                    //move letter to temp
	temp=temp>>4;                   //shift temp to right by 4
	lcd_nybble(temp,0);             //send the 4 out
	temp=temp&0x0f;                 //and out first 4
	lcd_nybble(temp,0);             //send out last 4
void lcd_char(unsigned char letter)
//This is the same as the lcd_cmd function except
//that is sets RS to 1 telling the lcd this is characters
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcd_nybble(temp,1);
	temp=letter;
	temp=temp&0x0f;
	lcd_nybble(temp,1);
void lcd_string(char *senpoint)
	while(*senpoint != '\0')            //While we havent seen a \0 (esc) go on
	    lcd_char(*senpoint);            //send 1st char to our char function
	    senpoint++;                     //send next
void lcd_nybble(unsigned char nyb,char rs)
	char i;
        char x;
        lcd_rs = rs;                    //Set RS Pin (defined in header file)
	for(i=0;i<4;i++){		//Loop through nybble
        if((nyb & 0x08) != 0)           //AND the nybble to 8
	    x=1;                        //if the AND == 1 set x
	else
 	    x=0;                        //if the AND == 0 clear x
        if(i==0)                    //select RA3:RA0 and set/clear pins
            lcd_DB7=x;
        if(i==1)
            lcd_DB6=x;
        if(i==2)
            lcd_DB5=x;
        if(i==3)
            lcd_DB4=x;
        nyb=nyb<<1;                     //shift nybble to the left by 1 (4 times total)
	e_togg();                   //toggle E pin (defined in header file)
ok found a mojor problem (well for me it is)
My Line:
tmp2 = ((s_time[0]<<4) | s_time[1]); // For setting Hour
How can i add to this line to set the 7:5 bits without changing the others?
The problem is it sets the clock for 24 Hour. I tried :
& 0b00011111;
(and)
| 0b01000000;
This produces a weird result. Lets say i set time to 12:01 it will change it to 62:01 or something like that.
Any thoughts?
Here is the address map.
ds1337d-jpg.22334
My Line:
& 0b00011111;
(and)
| 0b01000000;
Any thoughts?
ds1337d-jpg.22334
hi atom.
If I am reading correctly you are AND'ing bit6. 24/12 set
Shouldnt you OR it to set B6 in the hours byte.??
EDIT:
hrs = 12: 0001,0010
OR 12hr clock
bit 0100,0000
= 0101,0010 === 52h
I dont know much on "&" , "|" but heh
I tried both of them and no good result.
My Quick Fix:
        if(hours == 0x13){
            hours = 0x01;
            rtc_write(0x02,hours);
