Sony CD player not tracking properly
BobW
Active Member
I have an old Sony stereo system. Everything except the CD player works fine.
The CD player has a problem with the laser tracking assembly. It works okay for a while but then starts skipping. If I use the forward and reverse track skip buttons to work the tracking back and forth a few times, it seems to fix the problem for a while. So I think it's nothing more than the drive needing some cleaning and lubrication. Wondering what I should use for this.
Nigel Goodwin
Super Moderator
Most Helpful Member
Sewing machine oil on the sliders should be fine, though I generally use a TINY!! drop of WD40 on them, although you probably need to replace entire laser optical assembly - it's not likely to be down to lubrication.
spec
Most Helpful Member
One thing you can try is to clean the optics. Over the years they can build up a thin film which is quite hard to remove. I normally use IPA and a medium stiff artists brush.
spec
BobW
Active Member
Seems to me that I tried cleaning the optics not too long ago, but I may be thinking of a different CD player. The unit in question is away at the summer cottage, so I won't be able to get at it until the next time I'm out there, which will be a few days.
If it turns out that the laser optical assembly is bad, where does one find a replacement?
I'm wondering if audio CD drives are interchangeable the same way that CD data drives are. If so, the simplest solution might be to replace the entire drive part.
EE World Online Articles
Loading
