tiltawhirl
Hi all,
Been reading through the various threads but have yet to find something quite in line with my current questions. I hope someone can at least point me in the right direction. My electrical/electronics knowledge is limited to 'enough to be dangerous' but I do have a good handle on soldering and other basics of circuit design.
My question relates to taking 110ac voltage from the wall to run a 90v ac motor. Speed control is not that important, however reversing direction is a must. If it is possible to vary the speed, all the better.
What I am trying to wire is a 12" linear actuator which will be used as a lifting arm for one of my current models.
As you can see in the image, there is a black, white, and green, along with a brown and red which are spliced from the black and white that lead to the capacitors. I am assuming the brown goes onto the cap board(and has just come unsoldered) but I have no idea what to do from there.
Anyone want to give a little coaching on how to wire this thing for forward and reverse without killing myself?
Thanks in advance!
tilt
Thanks in advance!
tilt
