(Solved)Again problem with matrix, this time 8x32
I am worried though that you cant see scrolling, what about the binary values in the corner, they should be changing with time?
yes, they do blink & change thankfully. I played bit and managed to make scrolling counter with millis(), so RTC should be indeed possible!
I MADE IT! Scrolling DD/MM/YY HH:MM:SS
I'll upload code & video in a few! :)
and code(needs bit refining, seconds won't update while scrolling, I know it should be possible as I made 9999 seconds counter that scrolled and updated as scrolling) And for some reason couldn't place all stuff in one loop(), now date & time are separate, but it works. And thanks a LOW for you guys for help!!! :)
C:
#include "FontMap.h"
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int dataPin = 2; // ic: 14, ser_in Define which pins will be used for the Shift Register control
int latchPin = 3; // ic:12 silkscreen numbers!
int clockPin = 4;
unsigned char displayPointer = 0; // for interrupt use...
unsigned char buffer1[32]; // buffer for screen
unsigned char backbuffer[32]; // Spare screen for drawing on
unsigned char power[8] = {128, 64, 32, 16, 8, 4, 2, 1};
ISR(TIMER1_COMPA_vect) // timer compare interrupt service routine, called every now and then, outside of loop
  if (TIFR2) // Make sure its the timer interrupt.
  setcolumn(displayPointer);  //column scanning
  setdata(buffer1[displayPointer]);
  PORTD = (1 << PORTD3);
  PORTD = (0 << PORTD3);
  //digitalWrite(latchPin ,HIGH);
  //digitalWrite(latchPin , LOW ); // STORECLOCK
  if (++displayPointer == 32)
  { displayPointer = 0;
  } // 32 LED row sections in total
  TIFR2 = 0; // Clear timer 2 interrupt flag
void setcolumn(unsigned char col)  //loop that takes care of column scanning
  signed char pos;
  for (pos = 32; pos > -1; pos--)
  if (col == pos)
  PORTD = (1 << PORTD2);
  //digitalWrite(dataPin ,HIGH);
  else
  PORTD = (0 << PORTD2);
  //digitalWrite(dataPin ,LOW);
  } // PIN1 DATA pin
  //PORTD=(1<<PORTD4);
  //PORTD=(0<<PORTD4);
  digitalWrite(clockPin , HIGH);
  digitalWrite(clockPin , LOW);
void setdata(unsigned char dat) {
  unsigned char pos;
  for (pos = 0; pos < 8; pos++)
  if (dat & 128)
  dat -= 128;
  else
  //digitalWrite(dataPin ,LOW);} // PIN1 DATA pin
  dat = dat * 2;
void clr() //clear
  int addr;
  for (addr = 0; addr < 32; addr++) // Empty display buffer
  backbuffer[addr] = 0;
void Blit() //transfers data between display buffer to screen buffer
  int addr = 0;
  noInterrupts(); // disable all interrupts during setup
  for (addr = 0; addr < 32; addr ++)
  buffer1[addr] = backbuffer[addr]; // put all data from display buffer
  } // to screen buffer
  interrupts(); // enable all interrupts
void pixel(signed char x, signed char y, int cond)
  unsigned char pix, msk;
  if (x < 0 || y < 0) return; // outside drawing limits negative
  if (x > 31 || y > 7) return; // outside drawing limits positive
  pix = power[y];
  msk = backbuffer[x]; // get exsisting data
  if (cond == 2)
  pix ^= msk; // XOR data to screen
  if (cond == 1)
  pix = ~pix;
  pix &= msk; // AND data to screen
  if (cond == 0)
  pix |= msk; // OR data to screen
  backbuffer[x] = pix; // apply changes
void charput(unsigned char ch, signed char x, signed char y)
  signed char x1, y1;
  unsigned char disp;
  unsigned char disp2;
  for ( x1 = 0; x1 < 8; x1++) // eight rows
  disp = font[x1 + (ch * 8)];
  for (y1 = 0; y1 < 8; y1++) // eight pixels
  disp2 = disp & power[y1];
  if (disp2 > 0)
  pixel(x + x1, y + y1, 0); // OR the pixel to the display buffer
void strput(const char* ch, signed char x, signed char y)
  int addr;
  while (*ch )
  charput(*ch++, x, y); // write a string to the display buffer
  x += 7;
void setup() //setup runs once
  Wire.begin();
  RTC.begin();
  signed char cntr;
  DDRD = DDRD | B11111100; //port registers used to set pin directions
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1 = 0;
  OCR1A = 31; // compare match register 16MHz/256/2Hz -----------------------------------> delay time (lcd flicker/brightness)
  TCCR1B |= (1 << WGM12); // CTC mode, free-running, clear on match
  TCCR1B |= (0 << CS10); // 256 prescaler
  TCCR1B |= (0 << CS11); // 256 prescaler
  TCCR1B |= (1 << CS12); // 256 prescaler
  TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
} // End main
void loop() //just sitting here
  DateTime now = RTC.now();
  signed char scrollctr;
  for (scrollctr = 112; scrollctr > -8; scrollctr--)
  clr();
  charput(((now.day() / 10) % 10), scrollctr - 80, 0);
  charput(((now.day() / 1) % 10), scrollctr - 72, 0);
  strput("/", scrollctr - 64, 0);
  charput(((now.month() / 10) % 10), scrollctr - 56, 0);
  charput(((now.month() / 1) % 10), scrollctr - 48, 0);
  strput("/", scrollctr - 40, 0);
  charput(((now.year() / 1000) % 10), scrollctr - 32, 0);
  charput(((now.year() / 100) % 10), scrollctr - 24, 0);
  charput(((now.year() / 10) % 10), scrollctr - 16, 0);
  charput(((now.year() / 1) % 10), scrollctr - 8, 0);
  Blit();
  delay(100);
  for (scrollctr = 96; scrollctr > -8; scrollctr--)
  clr();
  charput(((now.hour() / 10) % 10), scrollctr - 64, 0);
  charput(((now.hour() / 1) % 10), scrollctr - 56, 0);
  strput(":", scrollctr - 48, 0);
  charput(((now.minute() / 10) % 10), scrollctr - 40, 0);
  charput(((now.minute() / 1) % 10), scrollctr - 32, 0);
  strput(":", scrollctr - 24, 0);
  charput(((now.second() / 10) % 10), scrollctr - 16, 0);
  charput(((now.second() / 1) % 10), scrollctr - 8, 0);
  Blit();
  delay(100);
and fontmap:
C:
static unsigned char font [1000] =  //numbers stored here
{ //Position, Character
  0x00, 0x00, 0x7E, 0x81, 0x81, 0x81, 0x7E, 0x00, // 0  0
  0x00, 0x00, 0x80, 0x82, 0xFF, 0x80, 0x80, 0x00, // 1  1
  0x00, 0x00, 0xC2, 0xA1, 0x91, 0x89, 0x86, 0x00, // 2  2
  0x00, 0x00, 0x42, 0x91, 0x91, 0x91, 0x6E, 0x00, // 3  3
  0x00, 0x00, 0x18, 0x14, 0x12, 0xFF, 0x10, 0x00, // 4  4
  0x00, 0x00, 0x4F, 0x91, 0x91, 0x91, 0x61, 0x00, // 5  5
  0x00, 0x00, 0x6E, 0x91, 0x91, 0x91, 0x62, 0x00, // 6  6
  0x00, 0x00, 0x01, 0xF1, 0x09, 0x05, 0x03, 0x00, // 7  7
  0x00, 0x00, 0x6E, 0x91, 0x91, 0x91, 0x6E, 0x00, // 8  8
  0x00, 0x00, 0x8E, 0x91, 0x91, 0x91, 0x6E, 0x00, // 9  9
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 10
  0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, // 11
  0x81, 0x42, 0x00, 0x18, 0x18, 0x00, 0x42, 0x01, // 12
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 13
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 14
  0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 15
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 16
  0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 17
  0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 18
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 19
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 20
  0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, // 21
  0x81, 0x42, 0x00, 0x18, 0x18, 0x00, 0x42, 0x01, // 22
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 23
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 24
  0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 25
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 26
  0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 27
  0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 28
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 29
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 30
  0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, // 31
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // 32  "space"
  0x00, 0x00, 0x00, 0xFB, 0xFB, 0x00, 0x00, 0x00, // 33  !
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 34
  0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 35
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 36
  0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 37
  0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 38
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 39
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 40
  0x00, 0x81, 0x21, 0xC1, 0xFF, 0x01, 0x01, 0x00, // 41
  0x81, 0x42, 0x00, 0x18, 0x18, 0x00, 0x42, 0x01, // 42
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 43
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 44
  0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 45
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 46
  0x00, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x00, // 47  /
  0x00, 0x00, 0x00, 0x00, 0x6C, 0x00, 0x00, 0x00, // 58  :
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 59
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 60
  0x00, 0x81, 0x21, 0xC1, 0xFF, 0x01, 0x01, 0x00, // 61
  0x81, 0x42, 0x00, 0x18, 0x18, 0x00, 0x42, 0x01, // 62
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 63
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 64
  0x00, 0x00, 0X7C, 0X0A, 0X0A, 0X0A, 0X7C, 0x00, // 65  A
  //0x94,0x5c,0xb6,0x5f,0x5f,0xb6,0x5c,0x94,
  0x00, 0x00, 0x7E, 0x4A, 0x4A, 0x4A, 0x34, 0x00, // 66  B
  0x00, 0x00, 0x3C, 0x42, 0x42, 0x42, 0x24, 0x00, // 67  C
  0x00, 0x00, 0x7E, 0x42, 0x42, 0x42, 0x3C, 0x00, // 68  D
  0x00, 0x00, 0x7E, 0x4A, 0x4A, 0x4A, 0x4A, 0x00, // 69  E
  0x00, 0x00, 0xFF, 0x11, 0x11, 0x11, 0x01, 0x00, // 70  F
  0x00, 0x00, 0x3C, 0x42, 0x52, 0x52, 0x34, 0x00, // 71  G
  0x00, 0x00, 0x7e, 0x10, 0x10, 0x10, 0x7e, 0x00, // 72  H
  0x00, 0x00, 0x00, 0x42, 0x7e, 0x42, 0x00, 0x00, // 73  I
  0x00, 0x00, 0x20, 0x40, 0x40, 0x3A, 0x00, 0x00, // 74  J
  0x00, 0x00, 0x7E, 0x18, 0x24, 0x42, 0x00, 0x00, // 75  K
  0x00, 0x00, 0x7E, 0x40, 0x40, 0x40, 0x40, 0x00, // 76  L
  0x00, 0x00, 0x7E, 0x04, 0x08, 0x04, 0x7E, 0x00, // 77  M
  0x00, 0x00, 0x7E, 0x04, 0x18, 0x20, 0x7E, 0x00, // 78  N
  0x00, 0x00, 0x7E, 0x81, 0x81, 0x81, 0x7E, 0x00, // 79  O
  0x00, 0x00, 0x7E, 0x0A, 0x0A, 0x0A, 0x04, 0x00, // 80  P
  0x00, 0x00, 0x3C, 0x42, 0x52, 0x62, 0x3C, 0x00, // 81  Q
  0x00, 0x00, 0x7C, 0x0A, 0x1A, 0x2A, 0x44, 0x00, // 82  R
  0x00, 0x00, 0x24, 0x4A, 0x5A, 0x52, 0x24, 0x00, // 83  S
  0x00, 0x00, 0x02, 0x02, 0x7E, 0x02, 0x02, 0x00, // 84  T
  0x00, 0x00, 0x3E, 0x40, 0x40, 0x40, 0x3E, 0x00, // 85  U
  0x00, 0x00, 0x1E, 0x20, 0x40, 0x20, 0x1E, 0x00, // 86  V
  0x00, 0x00, 0x7F, 0x80, 0x7F, 0x80, 0x7F, 0x00, // 87  W
  0x00, 0x00, 0x42, 0x24, 0x18, 0x24, 0x42, 0x00, // 88  X
  0x00, 0x00, 0x02, 0x04, 0x78, 0x04, 0x02, 0x00, // 89  Y
  0x00, 0x42, 0x62, 0x52, 0x4A, 0x46, 0x42, 0X00, // 90  Z
  0x00, 0x81, 0x21, 0xC1, 0xFF, 0x01, 0x01, 0x00, // 91
  0x81, 0x42, 0x00, 0x18, 0x18, 0x00, 0x42, 0x01, // 92
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 93
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 94
  0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 95
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 96
  0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 97
  0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 98
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 99
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 100
  0x00, 0x81, 0x21, 0xC1, 0xFF, 0x01, 0x01, 0x00, // 101
  0x81, 0x42, 0x00, 0x18, 0x18, 0x00, 0x42, 0x01, // 102
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 103
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 104
  0x00, 0x00, 0x00, 0x91, 0xBF, 0x01, 0x00, 0x00, // 105
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 106
  0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 107
  0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 108
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 109
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 110
  0x00, 0x81, 0x21, 0xC1, 0xFF, 0x01, 0x01, 0x00, // 111
  0x81, 0x42, 0x00, 0x18, 0x18, 0x00, 0x42, 0x01, // 112
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 113
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 114
  0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 115
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 116
  0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 117
  0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 118
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 119
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 120
  0x00, 0x81, 0x21, 0xC1, 0xFF, 0x01, 0x01, 0x00, // 121
  0x81, 0x42, 0x00, 0x18, 0x18, 0x00, 0x42, 0x01, // 122
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 123
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00  // 124
Move this line into both for loops
Hehe, thanks Ian, that did the trick, now seconds update while scrolling :)...
and thank YOU guys for your patience in allowing me to attempt at this, .... like I said , piece of cake! and only 200 post later! ohya, an ima steal that woof blit for myown youtube!
question: I'm trying to adapt this to 7 segment, is there any other changes needed that new fontmap and change buffer sizes as well as colum sizes?
yes, the 7 segment only needs 7 bits per letter, easier to round off to a byte, so each buffer would only be 1byte long, instead of 8 previously used, as for the rows, stick to ascii! If you are just doing numbers ascii doesnt matter so much since there wont be any strings getting passed through.
that also means the array will be smaller,in this line:
1000 is the number of elements we reserved in the array , so /8, we now only need 125 elements to fill the ascii map, and only 10 if you only plan to use 0-9
Thanks doggy, thought so. That code just makes life SO much easier because it can show pretty much any data and so It's perfect for my car computer project, but I'll probadly need to make 14 segment version too to show menu system better (alphanumeric characters). I'll try it first myself, font map I got already rewritten for 7 segment, even array size.
this I've gotten thus far, no sensible yet and can't find reason why:
C:
#include "FontMap7Segment.h"
int clockPin = 4;
unsigned char buffer1[4]; // buffer for screen, was 32 for matrix (4x8=32 and each character is built from 8x8 block, due 8x8 matrix) but for 7 segments, each character is 1x8 and screen is 4 digits so buffers are 4
unsigned char backbuffer[4]; // Spare screen for drawing on
unsigned char power[4] = {1, 2, 4, 8}; //B00000001,B00000010,B00000100,B00001000 for digits
// was: unsigned char power[8] = {128, 64, 32, 16, 8, 4, 2, 1};
  if (++displayPointer == 4)  //was 32, now 4 as buffer sizes changed too
  signed char pos;
  for (pos = 4; pos > -1; pos--)  //was pos=32, but again, only 4 columns now so pos=4
  if (col == pos)
  PORTD = (1 << PORTD2);  //digitalWrite(dataPin ,HIGH);
  else
  PORTD = (0 << PORTD2);  //digitalWrite(dataPin ,LOW);
  unsigned char pos;
  if (dat & 16)  //these dat were 128, but changed them to 16 as 16=128/8
  dat -= 16;
  else
  PORTD = (0 << PORTD2);  //digitalWrite(dataPin ,LOW);} // PIN1 DATA pin
  dat = dat * 2;
void clr() //clear
  int addr;
  for (addr = 0; addr < 4; addr++)  // Empty display buffer, reduced from 32 to 4
  int addr = 0;
  for (addr = 0; addr < 4; addr ++)  //here also changed 32 to 4
  buffer1[addr] = backbuffer[addr];  // put all data from display buffer to screen buffer
  if (x > 3 || y > 7) return;  // outside drawing limits positive, changed x>31 to x>3
  pix = power[y];
  if (cond == 2)
  if (cond == 1)
  pix = ~pix;
  if (cond == 0)
  signed char x1, y1;
  unsigned char disp;
  for ( x1 = 0; x1 < 8; x1++)  // eight rows, still eight bits to load so no changes
  if (disp2 > 0)
  int addr;
  while (*ch )
  x += 7;
  signed char cntr;
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1 = 0;
  OCR1A = 260;  // compare match register value, was 31 for matrix (1920hz= 60hzx*32) but for now there's only 4 columns so: 4*60hz=240hz; 16mhz/256/240=260
} // End main
void loop()  //main loop
  clr();
  strput("0123", 0, 0);  //test string to draw on segments
  Blit();
And fontmap as attachment
And tested fontmap functionality with this sketch:
C:
int dataPin = 2;  //Define which pins will be used for the Shift Register control
int latchPin = 3;
int clockPin = 4;
boolean newData = false;
void setup()
  Serial.begin(9600);
  pinMode(dataPin, OUTPUT);  //Configure each IO Pin
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
void loop()
  int i=Serial.read();
  digitalWrite(latchPin, LOW);  //Pull latch LOW to start sending data
  shiftOut(dataPin, clockPin, MSBFIRST, B00000001);
  shiftOut(dataPin, clockPin, MSBFIRST, font[i]);
  digitalWrite(latchPin, HIGH);  //Pull latch HIGH to stop sending data
  delay(500);
  • FontMap7Segment.h
oh ya , we also need to change the setcolumn, setdata and the isr that calls them, those were the code for shift register specifically for your previous config,
how do you have 7seg hooked up , is it on shift register too?
Oops, forgot to mention how circuit is. So yeah, I still use shift registers as they are "easy". Two registers chained in series, first controls anodes and latter columns/digits via darligton array. First is wired to segments as q0->dot, q7->g, and that's why first, q0 is "un-used" (I don't have decimal point in use at any character). The latter has digits covered, as so; B00000001=digit 0 on, B00000010=digit 2 on etc.
So baicly quite same setup as in matrix, I'll toss schematic in A few (need to draw it first)
This way:
in this one you no longer need setcolumn routine, instead just delete setcolumn, and change setdata sub so it bumps out one numeric value after another..
also your cathodes can go straight to ground, with the 7 seg we no longer need to call them individually
Umm, how come cathodes straigth to ground? Aren't then all digits be on all the time and digits show same value?
This display I use:
on a glance , i noticed that in set data a number got changed to 16, change it back to 128, 128 represents that we are shifting out the msb.
same with the power variable, it should remain 128
also in charput, this equation needs to be changed: disp = font[x1 + (ch * 8)]; it is no longer *8, and i think everything with x1 can be removed,
also try debugging with pixel and charput commands before using strput, since strput relies on using charput, and charput relies on pixel and fontmap
also in setdata, you may need to flip polarity at cathode, by flipping the top line here with the bottom line (maybe):
else
