Soldering issue for RS232 Serial connection
cimulation
I am trying to make a cicuitboard for my circuit which is prototypes on the breadboard.
There are serial port Tx and Rx pins from a PIC16f688 which i use to interface to the PC. On the breadboard these work fine, when i soldered these onto my board the trasmission has a lot of errors. I have checked the connections and I am using wires to solder these onto the board.
Is there a recommended way of soldering when a serial transmission is concernced. What can be done to prevent these errors.
Best Regards and TIA.
Sumit
You have to use a MAX232 to get the correct voltage levels, if you want to connect your PIC to a RS232 port.
Depends on the serial port. I have a Dell Laptop with a serial port and it reads CMOS 0-5V levels just fine.
Besides, if I'm interpreting the OP's post correctly, this used to work while his circuit was on a bread board, but it began not working properly when he built a permanent circuit.
My guess is that there is a missing ground between the computer's serial port and the circuit. The PIC Vss pin has to be wired the computer's ground (pin 5 on the serial port?).
