small question about pic assembly
wejos
this is 16f84, and according to what i've read, port A is 5 bit.
why in this code and i found in many examples as well, they used 8 bit to set port A;s input and output? am i missing something here?
start movlw b'00000001'
tris PORTA
movlw b'00000000'
tris PORTB
thank you in advance
Papabravo
Even if the bits #5, 6, and 7 do not go outside the chip they are still on the data bus. If thery have nowhere to go at the end of the write cycle they just fall off the edge of the Earth so to speak. There is no real problem that I can see.
be80be
I think it more like habit and a good one to keep Like the 12f683 only 6 pin for I/O and
you can set it b'000000 or B'00000000 both work same with any chip it reads from right to left so any past the 5 it uses. Get a 0 any way. And if you get in the habit of not
using 8 when you use a Port with 8 you'll do it wrong a time or to. I always use 8
EE World Online Articles
Loading
