Sleep related device design help needed
Somnonaut
I am looking to create a battery operated device, that connects thru usb to a computer to alter its user settings, and would allow two inputs of EEG and output an A/C signal of + 1 volt capable of being outputted to a polygraph.
Any takers?
I may be able to help...
Slight disclaimer though: I am fairly new to all this...
Google search 'embla sleep systems' let me know if thats what u want to achieve on a very basic level then get backb to me!
I am familiar with the Embletta. What I want is different. It goes along with this concept of mine.
www.z-eeg.com
I would want a box that piggy-backs on two leads presently used in polysomnography (C4 and M1) and the box would perform an FFT so as to yield the Z-ratio value, then the box would have 2 outputs (+ and - ) of +1V so as to be able to plug back into the polygraph to record the Z-ratio value onto the polygraph during the study. This would yield a system independent way to use Z-ratio during polysomnography (PSG).
All manner of various ways to output the values should also be within the box, with miniusb connection to configure said box via computer. Also, said box can be run in multiple mode when multiple boxes are run simultaneously, and using a multi-port USB hub, the boxes would simultaneously calculate z-ratio from various EEG sites, and thru the computer a brain map of z-ratio would be availed in realtime.
I have the sleep chops, not the electrical chops. I was planning on getting an arduino board and starting from there, but I do not know the next step. Pre-amp, Amp, filter, FFT, how to make the circuit etc.
Or I was wondering if one of these boards/kits would be more appropriate as it seems to have more available out of the box. graphic screen, serial screen. LED, inputs etc, etc.
http://www.mikroe.com/eng/categories/view/86/easy-start-kits-8051/
https://www.electro-tech-online.com/custompdfs/2012/05/easy8051_v6_manual_v100.pdf
I am lost with how to introduce the low level EEG voltage into the next step>Amplifer? And is there even an amplifier (if needed) for these boards (or Arduino)?
Oh wow look at this I found
https://www.electro-tech-online.com/custompdfs/2012/05/thereport.pdf
http://openeeg.sourceforge.net/doc/modeeg/modeeg_design.html
Finding lots of helpful stuff.
https://www.electro-tech-online.com/custompdfs/2012/05/JSSC_Jun_03.pdf
http://www.edaboard.com/thread18289.html
http://www.google.com/search?rlz=1C...rceid=chrome&ie=UTF-8&q=eeg+amplifier+circuit
http://medical-electronics-guide.blogspot.com/2011/01/unique-eeg-amplifier-detection-circuit.html
"Visible, to design a high-quality EEG amplifier, preamplifier must have input impedance is high, and high common-mode rejection ratio (CMBR), low noise, nonlinearity of small, strong anti-interference ability, as well as the appropriate band and dynamic range, which makes the performance such as RF amplifiers in the design of the major difficulties, but this is the entire EEG signal acquisition system designed for the success of the most important key aspect."
http://teknomage.wordpress.com/2008/08/15/eeg-schematic/ using http://www.ti.com/product/ina118
