What i am looking for is when you press a button a relay will (go up) work for xx seconds and when you press the same button again the relay will (go down) work for xx seconds,
The kit i am looking for is the exact same as a omega electric rear blind circuit, push the button the blind goes up and push it again the blind goes back down,
5 wires in total,
pos 12v
earth/ground
Button to ground,
and the other 2 wires would be the power which would get swaped for the motor going up and down.
I can take a pic of the circuit if need be, but i can only use the 555 chips as i have other kits which use them.
should be a easy kit but i have looked around but im struggling,
David
5 wires in total,
pos 12v
earth/ground
Button to ground,
David
