simulation model for ltspice
peter clarke
Hi, Anyone know where I can find a simulation model for lp339 or lm339 to work on ltspice? Tina-ti spice models do not work on ltspice because the software is different.
Hi
You can download one at the TI.com web site.
eT
I said that the TI models do not work on ltspice because the software is different. one is linear technology the other is TI or texas instruments
You should join the LTSpice Yahoo group. They have all sorts of models available:
https://groups.yahoo.com/neo/groups/LTspice/files
You will need a Yahoo account, but it's free to sign up. Once you do, go to "Files"and do a search for "LM339".
This TI model does work in LTspice. Downloaded from TI web site.
eT
Peter, do you know how to correctly add models to LTSpice manually?
LTspice works with PSPICE models. So any PSPICE compatible models should work. There are other models available, but these are incompatible
Here's one, I use it and works perfectly. Can't remember where I got it from.
Add an Op-amp, change the "Value" field to LM339 and add a ".sub LM339.sub" directive.
You can use LM339_DIP14 if you want all 4 op-amps.
